Thread: 1.9CDTI engine temperature?
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    150 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Default 1.9CDTI engine temperature?
    Hi everyone,
    what is the correct operating temperature for a 1.9cdti? My signum seems to run just below 80C most of the time according to the gauge. All the previous vauxhalls I've had normally operated at about 90C. It has done over 100k miles so perhaps the thermostat might be getting tired.
    Just wanted to check before I order a replacement. Is it a straightforward job to change the thermostat on the 1.9 cdti 120? I've done it on a 2.0dti Astra before, but I can't even find the thermostat housing on the Signum.
    cheers
    Paul.
    Redditch
    Mone runs anywhere between 80 and 85, done 101,800 miles
    Administrator plasma's Avatar
    On the Forum
    368 Post(s)
    Engine : 150
    Mileage : 74000
    as above... Change one on my old salvage project due to it barely reaching 80 if the heater wasnt on hot... new one cured it..
    need to do one of the show car as well.. Its right hand side of engine near the battery, remove the cover from the engine and you'll see it.. Bit knuckle strapey to do with the battery in the way but possible..
    btw, its an all in one housing...
    Sep 2009
    Glasgow
    mines didn't register above 75 but after inlet manifold was replaced it quickly reaches around 80 - 85
  1. Engine temperature up and down
    By benwalters82 in forum Engine & Drivetrain
    Last Post: 7th March 2013, 21:01
  2. 2.2 DTI engine temperature
    By Alistair123 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th November 2011, 00:21
  3. 1.9cdti coolant light and temperature guage help please.
    By martin19842 in forum Engine & Drivetrain
    Last Post: 10th March 2011, 10:39
  4. 1.9CDTi engine temperature
    By WilliamLX in forum Vectra C / Signum Car Chat
    Last Post: 11th November 2010, 23:30
  5. Engine temperature
    By NI-2.2SRI in forum Engine & Drivetrain
    Last Post: 2nd February 2009, 11:40
vectra c engine temperature
1.9 cdti temperatur
opel vectra c engine temperature
