Results 1 to 10 of 18
Thread: service question
    Regular Member rickeys16v's Avatar
    N.Ireland ( Broughshane )
    Vehicle : 1.9 CDTI 150
    Trim : SRI
    Mileage : 46000
    Default service question
    just a little question but is it every 10,000 miles for a service on my cdti and is it at 80,000 the belt should be done
    is it ok to go 1,000 over the service of is it bad for it
    thanks..
    Regular Member Teapot's Avatar
    woodbridge, suffolk
    128 Post(s)
    Trim : Design+
    Engine : 1.9 CDTI 150
    Mileage : 101000
    Quote Originally Posted by rickeys16v View Post
    thanks..
    Vauxhall quote 20k as the service interval, but I personally think that's too long to leave the same oil in the engine. I change the oil at least every 10k on my cars. Going 1k over the service schedule won't make enough difference to worry about.
    80k sounds about right for the cambelt, but if you are paranoid like me you might want to get it done every 60k.
    Regular Member DaveW555's Avatar
    Cannock
    Vauxhall list that the timing belt interval is 100k on the cdti's but i'd never leave a belt that long, 60-70k tops, as for the servicing i do the oil and filter every 6k and the rest every other oil and filter change (12k).
    As a 2005 your car is probably out of warranty, unless you have bought the car recently
    If the car is under any type of warranty then you are allowed up to 500 miles beyond the previous service
    Equally, if the cambelt fails prematurely out of warranty then providing it has been fully serviced by VX they will normally pay an amount towards any repair costs
    If the car has not been serviced by VX or is not covered by any warranty then you can use any service schedule you like
    As above, most people cut it from 20K miles to 10K miles
    Equally, cut the cambelt change from 80K miles to 60K miles (note on some engines VX normally cuts this original interval in half and I always do that for any VX engine)
    1000 miles over last service won't damage the engine, but it won't do it any good, the oil will simply be saturated in contaminants
    Eventually it will become acidic and attack the metal (usually the liners)
    In the interim get at least an oil and filter change
    You can (should be able to) change the pollen and air filter yourself
    That then just leaves the suspension and steering to check
    Jan 2010
    Berkshire
    I'm at 86000. Not going to have the cambelt changed until 99000 (November) - recommended interval is every 100K for the CDTI. I'm pretty confident the belt will be fine (touch wood). I'll update you if it changes, but from my experience cambelts usually last much longer than the manufacturer recommends.
    As for oil, I do around 28K miles per year so I think that once a year every 20k will also be fine as per the manufacturer's recommendation, but then I do mainly motorway miles. Last service was 5K ago and the oil's still a nice colour. Every 6K seems a bit 'extreme' to me. :-)
    Trim : SRI
    Mileage : 46000
    thanks for the replys everyone another couple of questions ( i know very little about cars) but im learning thanks to the people on here
    the pink fluid mine is quite low could that have anything to do with the car heating up to 85c when in traffic the odd time cause its very warm when i take the cap off
    this is the really stupid question do i need to put water in the car besides the washers
    yes i sound thick but everyone has to start some where :-)
    typical i cant find the oil i got last time and its not cheep
    You shouldn't be taking off the coolant reservoir cap (large yellow one)
    The only time you should need to remove it is when the engine is COLD and it needs checking or topping up
    With the car cold and level, there is a mark on it "KALT" and an arrow
    The liquid should be perfectly level with that arrow
    The liquid is typically 50% coolant and 50% water, so if you need to topup try not to use water only
    85'C in standing traffic is quite normal
    Equally, after a short drive and then coming to a stop the engine temperature will rise and the cooling fan may activate
    I'd be more worried if the gauge went about 90'C and/or the cooling fan didn't come on (not to be confused with the air con fan)
    When checking the oil, run the engine for a few minutes, then switch off, allow it to cool, and for the oil to settle
    Use any synthetic oil; TESCO do two litre bottles for about £6
    Glasgow
    Quote Originally Posted by Giw View Post
    Good luck it will be very expensive if it does go
    Full Member Big Sig's Avatar
    pretty confident doesn't fill me with confidence. I'll never understand why people do not keep on top of simple things on what is probably the second most expensive thing they own!
    Glasgow
    Its not just that the belt could snap there is other factors like the tensioner. Its like playing roulette with your car. Not for me lol.
  1. Service question
    By davidlewis24 in forum Vectra C / Signum Car Chat
    Last Post: 22nd July 2009, 13:04
  2. Service question...........
    By vectra 120 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2008, 22:14
  3. Service Question - Oil
    By cdtisri in forum Vectra C / Signum Car Chat
    Last Post: 21st May 2007, 21:07
  4. Sorry but Service Question
    By Perry in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2007, 11:57
  5. Hi again + 2nd Service Question
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 24th August 2006, 17:23
