Thread: Temp Guage - But already replaced :(
    Oct 2009
    Teesside
    Question Temp Guage - But already replaced :(
    Hi guys,
    I had the Thermostat replaced last winter as the guage would drop to zero and bounce back up again and since doing it i've had a steady 86oC all the way.
    However in the last week i've noticed that when driving in traffic or if giving it some stick the temp guage will go up to near 90oC and then fall down again when on the move.
    However when driving on a motorway or long road it will sometimes drop to around 83oC
    Could it be the recent weather affecting this, as its stuck on 86oC normally since I got it i'm sure (but I did buy it last August and we know what the British weather is like ).
    Its a 1.9 CDTI 150
    Thanks in advance guys
    Oct 2009
    Teesside
    I should say I've done all the usual checks like fluid etc (and I searched the forum for answers but couldn't find this problem).
    Regular Member DurhamRed's Avatar
    Co. Durham
    Vehicle : Vectra SRi
    Engine : 1.8VVTi
    Try the coolant temperature sensor. Mine had a very similar if not identical issue and this cured it. It isn't an expensive or labourious task to change it.
    Sep 2009
    Audley STAFFS
    Quote Originally Posted by robert_dale View Post
    Hi guys,
    Its a 1.9 CDTI 150
    I wouldnt say anything was wrong,its about the same as mine,, did the stat on mine, sits about 87 degrees, rises to 90 in traffic, and 85 on the Mway with the heater on number two
    Oct 2009
    Teesside
    Cheers guys, doesnt seem to cause any running problems as such and im starting to believe its actually just the weather to be honest with it being a bit warmer.
    I only changed the temp sensor the 6 months ago, and unfortunately for the 150 cdti you have to buy the whole unit which is £50!
    If it sounds about right i'll leave it for a while and see how she goes
    Regular Member Mark0's Avatar
    Scotland
    Sounds normal to me.
  1. 2.0 dti temp guage
    By stj in forum Engine & Drivetrain
    Last Post: 26th November 2013, 11:47
  2. temp guage ???
    By mauricemersey in forum Engine & Drivetrain
    Last Post: 23rd December 2012, 13:13
  3. temp guage and fog light problem
    By coooky in forum Vectra C / Signum Car Chat
    Last Post: 29th May 2011, 08:17
  4. temp guage problem
    By sri-case in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2010, 21:17
  5. How to fit an oil temp guage on my Signum?
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 6th September 2009, 12:09
