Thread: Large external sticker
    Regular Member george1987's Avatar
    Nov 2009
    Plymouth/Southampton
    Default Large external sticker
    Hi all,
    Received my vectra c.com sticker the other day. I'm just wondering how you put yours on? If I pull away the white backing then put it on the window, will the lettering stay on the window when I pull the other bit off? I'm making myself sound stupid with such a silly question, but as you all know, don't want to get anything wrong when it comes to the car
    Cheers,
    George
    WGAF#5
    ensure the surface is perfectly clean and then you should "offer up" the sticker to the vehicle so that it reads correctly and then remove the backing from the side closest to the vehicle
    then CAREFULLY place the sticker onto the surface you want to stick it to and then rub over the backing repeatedly to "activate the glue and help it to bond - rub it all over and then use a cloth to ensure you have pushed it all onto the surface - then SLOWLY from a corner start to remove the backing sheet if at any stage any of the decal starts to lift - replace the cover and rub repeatedly again for about another 30 seconds.. then try again.. keep going until all the backing is removed -then stand back..... grin from ear to ear and take a photo and pop it up
    Nov 2009
    Brilliant answer! I like it. Will go and do it soon. Thanks deztroyer
    WGAF#5
    no prob's George - i'm looking forward to the results
    regards
    Dez
    Nov 2009
    Here we are then. Once it was on, I did exactly as you told me to do - .
    Attachment 31934
    Attachment 31935
    It went a bit wrong at the start and I got a little pee'd off with myself, but after calming down, it went on quite easily. Unfortunately though, it looks slightly wonky . Oh well, still happy with it
    WGAF#5
    very nice
    Regular Member simplesi's Avatar
    Aug 2009
    probably off taking photos
    Vehicle : 1.9 cdti 150
    Trim : elite
    just a tad up on the left as you look at it but good job all the same
    Regular Member danlat1415's Avatar
    Lancashire
    A good tip is to wet the car with water/car shampoo mix (as you would when washing).
    This way, the stickers can slide around easy until you get the in the correct position, and as the water/shampoo dries, the sticker sticks to the car as normal.
    Is saves all the hassle of trying to peel it back off if you get it slightly wonky.
  1. Large Ladies..
    By macdad in forum Comedy & Humour
    Last Post: 21st June 2012, 19:40
  2. Little and Large
    By gaz1965 in forum Quick Photo Album
    Last Post: 17th May 2011, 08:27
