Results 1 to 10 of 14
Thread: Will it fit???
    Regular Member Nav-Man's Avatar
    London
    Default Will it fit???
    Can anyone tell me if that silver/chrome trim that goes across the dash on the facelift 2007 vectra will fit onto a 2002 Vectra Sri?
    I found that trim at my local scrappy, but don't want to shell out the money just to find out that it won't fit.
    Yes it will
    London
    Thanks for that.
    Just realised that would have the change the trim on the door cards as well, so will have to go back and check if the car has those, so that I don't end up with different shades of grey on the car.
    Thanks again
    The door card strips can be removed, they are held on with plastic lugs iirc, they may break when removed but the strip can be hot melt glued back on etc.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    The strip acros the dash from a facelift will not fit a prefacelift, due to the diffence around the radio.
    milton keynes
    The strip across the dash does fit , as thats whats in mine. Saying that I have facelift vents too
    London
    Quote Originally Posted by kman247 View Post
    Yeah, I have the facelift venst on mine too, the only thing I was a bit worried about on the strip was the length and also the clips, the shape looks to be exactly the same as the prefaclift.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    No it will not fit as the radio area on a facelift sticks out so the trim has a cut in it. I learnt this the hardway (£)
    Nov 2007
    How did ya get round the rounded corners fitting a square hole???
    London
    Quote Originally Posted by steve View Post
    Ah, I understand what you mean, HOWEVER there's no cut on it (see pic below) and even if there was, it would be ok because I have fitted a chinese double din head unit specific for the facelift Vectra which sticks out a bit, so it will fit perfectly.
    But yeah, it should fit ok.
    Ps. The pic is not from my car, but the interior is exactly the same as the car at the scrappy.
