Thread: Radiator Leak
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default Radiator Leak
    Chaps,
    Advise please - my rad has been leaking for months, I've tried rad weld which only slowed the problem rather than cure. I think it's a pin hole leak as it's damp round bottom of the bumper and leaves a small damp patch on the road, and needs topping up evey 2-3weeks.
    My question is can I get it patched / soldered up at all? Is there a system to do this in situ, as the rad I think is about £175 without fitting and looking in the Haynes manual a right ball ache to get to / swap out.
    Jul 2009
    The Rift, Cardiff
    Best to get a new rad. Mind was rusted where the rad meets the plastic end piece. I paid £150 fitted at a local independent garage. Should have done it myself tho, the rad was £70-80.
    I personaly wouldn't use any rad-weld type stuff, heard many horror storys bout it blocking the heater matrix, resulting in costly repair. But some on here have used it without problems.
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by ChrisBilly View Post
    Yeah it didn't seem right but like you say, some people swear by the stuff! German & Swedish want £110 for one, which even the guy there thought was expensive but the dealer price he has is £180 so I don't think so bad!
    Anyone know where I can get one cheaper? It's a 2.2DTi btw!
    Regular Member DaveW555's Avatar
    Cannock
    Euro Car Parts - £68.95 online price, I'm sure if you've got a mate in the trade they'd get discount off that on top.
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Vectra elite
    Engine : 1800
    Mileage : 80000
    a lot off new type rads are crimped and so cannot be fixed... my bro in law said try k seal as will not block the heater rad up and is the best stuff on the market and is use for the k series engines ,, he should know as owns his own rad company here in leicester
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by DaveW555 View Post
    Excellent - just looked and that one's out of stock. How do I check it's the right one as I find Euro Car Parts always list loads of different units that it gets confusing? is the part number written on the rad for me to reference?
    Cannock
    they might have it in branch tho, just ring your local branch and give them your reg number.
    Apr 2009
    Stevenage, Herts
    Right,
    Still haven't done ANYTHING about this - has anyone changed their Rad before, and do they have any tips or tricks? I'm just concerned about having to take the headlights and bumper off, then the fact there being NO ROOM to work in as everything's wedged in between engine block and bumper!
    Changed the Rad on my old Golf GTi MK4, and that was tricky but loads of room compared to this car!
    Help please!
    Chelmsford
    I changed mine about 6 months ago, got the replacement for £50 from http://www.discount-cooling.co.uk/
    The job was a piece of cake. No need to remove the headlights, just the bumper.
    Make sure you don't let the A/C rad hang on it's pipes (it's usually bolted to the normal rad), I tied it up with string while I did the rest and everything was fine.
    Only thing I forgot to do was get the new style mounts from the stealers, I had to refit the old springs which make a dreadful noise.
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by DNS View Post
    Excellent - thanks for the link!!! They do it for £61+delivery so will snap that up next week! I take it the mounts/springs will be apparent when I'm in there??
  1. Vectra Radiator Leak
    By salmanking in forum Vectra C / Signum Troubleshooting
    Last Post: 4th May 2012, 19:37
  2. Slight Radiator Leak
    By stevie16v in forum General Chat
    Last Post: 19th February 2012, 15:47
  3. Radiator leak
    By dansoap in forum Engine & Drivetrain
    Last Post: 22nd April 2011, 21:22
  4. 1.8 sxi radiator leak
    By bat30 in forum Vectra C / Signum Car Chat
    Last Post: 3rd August 2009, 12:51
  5. radiator leak
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2008, 07:17
