Results 1 to 3 of 3
Thread: Noisey Roof Lining - Help!!!
    cumbria
    Default Noisey Roof Lining - Help!!!
    Hello All
    im new to this forum, but have a problem with my vectra which i hope someone can help me with.
    I have recently purchased a vectra estate and in the last couple of weeks it has developed a creaking noise coming from the roof lining / roof in the B pillar area.
    does anyone know how i can remove the lining to have a llok at what is casuing the problem?
    im a bit of a novice but have a good techincal back ground, so im not affade to give it a go myself.
    If anyone can halp please do
    Regular Member Innes's Avatar
    Plymouth
    Welcome to the forums. There is a 'How2' Guide in this forum as to how to remove the head lining of the Vectra C hatchback to replace the arial base properly.
    http://www.vectra-c.com/forum/showthread.php?t=82432
    Unfortunately its not an estate like yours but may be a big help as a guide when it comes to removing the seat belt and side airbags. Basically its not easy and you have to remove ALOT of stuff! I was considering doing it to replace my Ariel base due to the perished rubber but when I saw how tricky it was I reconsidered it!
    Hope this begins to point you in the right direction. Good luck!
    Regular Member DaveW555's Avatar
    Cannock
    Buy a cheap sponge, and wedge it between the roof and the headlining where its rattling, problem solved, you dont necessarily have to drop the headlining all together just find the rattle and drop the nearest corner. Hope this helps.
  1. Roof lining
    By Swedge in forum Bodywork & Interior
    Last Post: 7th January 2013, 13:46
  2. Roof Lining
    By Ian-Highlander in forum Bodywork & Interior
    Last Post: 1st March 2012, 21:47
  3. Roof Lining
    Last Post: 20th January 2011, 10:42
  4. Roof lining
    By sanjeevgangar in forum Parts for sale
    Last Post: 17th March 2009, 18:10
  5. Roof Lining down
    By plasma in forum Vectra C / Signum Car Chat
    Last Post: 3rd June 2008, 04:30
