Results 1 to 10 of 17
Thread: Indicators on facelift
    Sodding Typical on Sea
    Default Indicators on facelift
    I have just been reading the online owners manual and I don't get this you can access and change the headlamp bulb's easily enough, but it says to refer to the dealer for the indicators???????
    What is so difficult on this one? access, mounting, fitting? Never had this before on a mainstream car, I can tell you a BMW 7 series, the big bloated ugly one! takes 6 hours labour from BMW to change a side light bulb though
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    iirc the front bumper is supposed to come off to change bulbs on the facelift. If you have small hands then you may be ok
    Ahhh,,,,,,, It just didn't make much sense but I guess they must be tucked under the cross member then, small mit's and a mirror may scrape by, I knew I had a 5 year old daughter for a reason
    11 Post(s)
    IIRC from when I fitted my HID kit, there isn't enough room for the indicator socket to be removed from the headlight assembly without first pulling the headlight forward because the inner wing gets in the way. It's also easier to change the drivers side headlight bulbs with the bumper off and headlight out.
    Regular Member VECTRAMAN's Avatar
    Bridgend/South Wales
    Vehicle : 1.9 CDTI Design Estate
    Trim : Half leather
    Engine : 1900
    Mileage : 116k
    To change my headlamp bulbs I unbolted the airbox and moved aside for plenty access space and on n/s just took off the top half of washer bottle.easy peasy.
    11 Post(s)
    Unbolting the airbox, or removing the bumper takes about the same amount of time. As I wanted to mount the ballasts under the headlights, it was easier to remove the bumper to gain access.
    I previously tried changing the offside dipped bulb (before I got HIDs) by moving the airbox out the way and I suffered far less grazes and cuts to the back of my hand by removing the bumper 2nd time round.
    Regular Member george1987's Avatar
    Nov 2009
    Plymouth/Southampton
    I apologise for this, but couldn't justify starting a new thread for a question relating facelift indicators.
    Are the silvatec bulbs (silver coated ones from ebay/halfords etc) different on the front compared to the rear? I bought and changed the rear indicators, but didn't know if the front were the same design (offset pins). Your help is appreciated. George
    Glasgow
    Heres a link to a list of every bulb fitted to a vectra so you can see whats what http://www.vectra-c.com/forum/showthread.php?t=100938
    Edinburgh
    what? you must be the fastest bumper remover in the world.
    Airbox = disconnect pipe and pull airbox out
    bumper = 3 screw under each arch, 4 plastic rivots under bumper, 4 screws on top then unclip each side
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    and thats assuming that all of those silly torx screws come out easily
  1. How are the side indicators removed on a facelift vectra?
    By Deann in forum Electrical & ICE (including SatNav)
    Last Post: 11th September 2011, 01:07
  2. Facelift Front Chrome Indicators ?
    By Envy in forum Styling
    Last Post: 12th April 2011, 21:39
  3. Facelift indicators
    By george1987 in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2010, 19:23
  4. facelift indicators
    By dilan in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2010, 17:07
  5. Facelift front indicators
    By blue estate in forum Bodywork & Interior
    Last Post: 30th March 2008, 17:19
