Results 1 to 10 of 14
Thread: Running lumpy, engine management light and fault codes! Help please!
    Regular Member chris_sri's Avatar
    New Mills, High Peak
    Default Running lumpy, engine management light and fault codes! Help please!
    Well, my 2003 Vectra 1.8 sri dual fuel has been running rough recently, but only from start up when cold and within a minute it's running fine. Today the engine management light came on and is reporting fault codes 2103, 0170, and 0565.
    It runs on petrol on start up, and after a minute or so runs well, and then switches to LPG as normal. It runs fine in both petrol and LPG mode. The problem only occurs when the engine is stone cold in any outside temperature.
    Could anyone shed any light?
    I don't think my engine has an EGR?
    Could it be a MAF sensor problem?
    Thanks guys, and as always, any advice appreciated.
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    P0170 - Fuel Trim Malfunction (Bank 1)
    P0565 - Cruise Control On Signal Malfunction.
    B2103 - Antenna Not Connected ? - Don't think this is right, but I have no listing for P2103
    Does this help in any way?
    Yes your car will have an EGR valve!! and it will have either a MAF or MAP sensor.
    MAP and MAF only operate to control fuel mixture when accelerating and usually at full operating temperature.
    Lumpy idle when cold, could be a dodgy Coolant temperature sensor
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    I wouldn't worry too much about this code:
    I get this on mine occasionally and it doesn't even light the engine management light.
    Activating the cruise control via resume function on a long straight road 15-20 times is enough to clear this.
    It is caused when the resume button on cruise doesn't quite make contact.
    I've found out that code B0565 is 'Coolant temperature indicator circuit malfunction'.
    How do you differentiate between P, B, C and U codes?
    So if i've got a 'B0565' coolant temp sensor problem, then that's causing the cold idle problem and that, in turn, could be causing the P0170 Fuel trim malfunction?
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    If you have a Vauxhall / Opel / Holden / Saab specific diagnostic tool, then it will possibly give the prefix letter....
    Most vauxhall codes are P prefix, but there are others listed on general EOBD II diagnostic tools...B, C, P and U just depends on the sales make etc.
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by chris_sri View Post
    This sounds the most plausible fault...also a coolant temperature sensor is quite a cheap component to buy.
    Check connectors for cleanliness / corrosion first, before paying out for a sensor / sender.
    Regular Member DaveW555's Avatar
    Cannock
    I'd go for temp sensor first and if that doesn't cure it probably a maf sensor, its usually maf sensor that flags the 0170 code.
    Jul 2009
    The Rift, Cardiff
    Where is the coolant temp sensor on 1.8's?
    Quote Originally Posted by ChrisBilly View Post
    Its fitted into part of the thermostat housing.
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by DaveW555 View Post
    MAF sensor only throws up the code when accellerating.
    At cruise and idle, the Lambda sensors control all the emissions etc.
    If the car feels like it is running on just three HT leads, then in order of cost effectiveness / cheapness
    1) Check for air leaks around inlet manifold
    2) Check HT Circuit is clean and dry and working fine
    3) Clean the MAF sensor if it is a hot wire device (gently using carb spray)
    or
    ..if it is a vacuum controlled item (MAP sensor) then check the vacuum hose is not split
    4) Check the Coolant Temp sensor and replace if required.
  1. Engine lumpy now Engine Management Light is on
    By Fitzy-2.0T in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2012, 16:51
  2. Replies: 3
    Last Post: 23rd November 2011, 15:07
  3. Fault codes and lumpy drive help
    By vwsaxon in forum Vectra C / Signum Car Chat
    Last Post: 18th April 2011, 17:28
  4. New car fault codes and engine management
    By lutontownfan in forum Vectra C / Signum Car Chat
    Last Post: 28th November 2009, 18:47
  5. Engine Management Light, fault doesn't show on U480 scanner
    By petesaysblimey in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2009, 16:51
vectra lumpy engine management light on
whats engine code for vectra c 1.8 dual fuel 2003
vauxhall vectra running lumpy
vectra b engine management light car running lumpy
engine management light codes
vectra idle blink engine management
my vauxhall zafira b engine light on running lumpy
