Results 1 to 10 of 11
Thread: Acronyms explained?
    Liverpool
    Default Acronyms explained?
    hi all, i like to think i know a little bit about cars but some of the terminology/acronyms used on this site send my head west, can anyone explain what they mean i.e EGR, DPF, swirl valve,
    Regular Member luke4487's Avatar
    Bordon, Hampshire
    I know EGR is exhaust gas recirculation (ie reburning of some exhaust gas in the cylinders)
    WGAF#5
    Dpf
    diesel particulate filter
    egr
    exhaust gas recycling
    HID
    HIGH INTENSITY DISCHARGE
    afl
    adaptive forward lighting
    esp
    electronic stability programme
    abs
    assisted braking system
    pdc
    park distance control
    tla
    three letter abbreviation
    Regular Member R13hard's Avatar
    Devon
    Engine : 2.0 Turbo
    MAF = Mass Airflow Filter/Sensor
    DMF = Dual mass flywheel
    Liverpool
    Top men, cheers!
    Swirl Valve = Its a valve in the inlet manifold that makes the air/fuel "swirl" for better combustion.
    Wales, UK
    ABS
    Anti-lock Braking System.
    TC
    Traction Control
    CAT
    Catalytic Converter
    DOHC
    Double Overhead Cam
    ECU
    Engine Control Unit?
    TDC
    Top, Dead & Centred.
    Cant think of any more lol
    Full Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Here's a few that I thought of...
    ABS - Anti Lock Brake System
    AC - Air Conditioning
    BCM - Body Control module - found behind glove box
    BID - Board Info Display
    CC - Cruise Control
    CID - Colour Info Display
    CIM - Collumn Integrated Module
    DAB - Digital Audio Broadcast Unit
    DDM - Drivers Door Module
    DIAG - Diagnostic (Usually refers to port or connector)
    DIS - Display
    ECC - Electronic Climate Control
    EPC - Vauxhall's Electronic Parts Catalogue (pc based catalogue)
    GID- Monochrome Graphic Info Display
    HU or EHU - Head Unit / Main radio unit
    IPBEC - Instrument Panel and Body Electrical Centre - fusebox at end of the dash panel.
    OP COM - European version of Vaux Com - Diagnostic Interface and software
    PDM - Passenger Door Module
    REC - Rear Electrical centre (fuse box in the boot)
    TECH 2 - Vauxhall's own programming and diagnostic tool.
    TID - Triple Info Display
    TIS - Vauxhall's Technical Info System (pc based workshop manual)
    UEC - Underhood Electrical Control Centre - below fusebox under the bonnet
  1. The Banking Crisis explained
    By Derek Mc in forum Comedy & Humour
    Last Post: 24th October 2012, 11:58
  2. the 2.2 coil pack explained
    By jpbroad1970 in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2012, 23:21
  3. EGR explained - all you wanted to know and more
    By hebblemarine in forum Diesel Engine related
    Last Post: 2nd September 2011, 20:08
  4. Exhaust Systems Explained
    By spoons in forum Petrol Engine related
    Last Post: 25th August 2011, 22:50
  5. Acronyms
    By Trick202 in forum General Chat
    Last Post: 12th January 2008, 21:56
