Results 1 to 10 of 16
Thread: Dashboard Display
    Rotherham
    Default Dashboard Display
    Hi everyone..... can anyone help a newbie??
    I am the proud owner of a Vauxhall Signam 2.0t
    I have a problem with my dashboard, and it's driving me potty. The display in the centre console above the radio, which displays fuel range, time etc, and also the little display on the main panel underneath the rev counter and speedo, that states the mileage is really really dull, to the point where you can barely see it!
    Can anyone tell me if this is a problem they have had, or if there is a easy fix to this problem??
    I've tried the control to increase the brightness on the dash, and this works fine with the back lighting but has no effect on the displays mentioned above.
    Am I facing a trip to the steelers??
    Please help me get on with enjoying my car!
    Many Thanks,
    Dave.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Might help to know how old your SignUm is.... I assume it's possible for backlighting lamps to degrade like any other.
    First though, I'd have to give the standard answer regarding the illumination control sbove and right of the headlamp switch... if you haven't already you should press it in so it pops out, then gently twist it to the right as far as it goes and hold it there until the illumination goes as high as possible.This will only work when you have the side or headlamps switched on.
    Regular Member david.aka.judas's Avatar
    Suffolk
    what stereo/ head unit do you have?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Also does it change contrast when you turn the lights on? Try going into the settings and make sure its on auto.
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    I have mine set to night time permanently - looks much better. dont know if that would help or if it is just degraded SMD's etc thats causing your issues...
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by leemarksmith View Post
    I've converted mine to white so it looks better in the day LOL
    Rotherham
    Hi Guys,
    Thanks for your quick response.
    I have a 2004 Signum Elegance. I have tried the little pop out switch at the side of the headlight switch, but all this does is make the main display lights behind the speedo dials go brighter and duller, but it doesn't effect the display above the head unit or the display that shows the mileage.
    Also when you turn the main headlights on it has no effect on the problem displays contrast either.
    For want of sounding foolish, how do you enter into the settings menu as advised above?? and what are degraded SMD's??
    Many Thanks,
    Dave.
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Would help to know which headunit you have ?
    SMD - surface mounted device (flat LED mounted on a small circuit board)
    Rotherham
    Hi Andy,
    The headunit says CCR2006 on the front of it? Is this the info that your looking for?
    Dave
    21 Post(s)
    Mileage : 110k
    Same as mine, have you entered into other settings before - using the wiper stalk?
    Cant remember the exact selections to change setting but its easy to find on my display...
  1. Dashboard display is kapput (me thinks)
    By mcpitman in forum Electrical & ICE (including SatNav)
    Last Post: 13th September 2012, 21:24
  2. Replacing Board Info Display (BID) with Color Info display (CID)
    By grigs1 in forum Electrical & ICE (including SatNav)
    Last Post: 11th April 2012, 22:13
  3. Central Dashboard Display & Radio cut out / reset problem: 2004 Vectra 1.8
    By mikethemechanic in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2011, 14:34
  4. Disco display on dashboard
    By the_wave_rider in forum Electrical & ICE (including SatNav)
    Last Post: 17th January 2011, 18:57
  5. temp display on radio display
    By MRunMotorsport in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2010, 15:55
