Page 1 of 36 12311 ... LastLast
Results 1 to 10 of 351
Thread: Diy cdti oil catch tank
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default Diy cdti oil catch tank
    Hi all I have done a free diy catch tank
    equipment I have used is
    500ml pop bottle
    1meter of garden hose
    itg sock filter
    and a blanking plug
    I 1st drilled holes in the plastic pop bottle at the top near the neck drilled about 20 3mm holes i then cable tied the sock filter over the holes so it's filtered I then drilled a hole in the screw cap big enough the push the garden hose into. I located the bottle just in front of the drivers wheel in the bumper where the flap is on te undertray
    I fed the hose up through the engine bay and attached it to the oil seperator breather hose so now the oil will breath into the bottle and vent to atmosphere. While collecting in the bottle which I can screw out to empty
    I then took of the rubber pipe that comes from the inlet pipe just after the maf where the pipe would normally breath onto the inlet system and I have blanked this so it's air tight
    I mow have a oil free inlet system while it's venting to atmosphere
    total cost is nothing
    I have pics which I will put up soon and now I can monitor how much oil will collect in te bottle
    Any comments welcome I know it's scabby lol but all you can see is a little bit of garden hose as the bottle is hidden and can only be seen by pulling the flap down
    Pics to follow either today or 2moro when I put them on computer
    kings lynn, norfolk
    pics as i promised
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    This will stop the oil residue from entering the inlet system! And will eliminate the crud type material build up in the manifold as you will now only have hot/dry sooty residue entering the manifold via the EGR witch will 'not' cause any problems in the manifold!, its only when the 2 mix the problem occurs!, Also i don't think and I'm fairly sure you wont get much oil in the bottle 'if any', The ''draw'' from the pipe you have diverted from has a sucking action within the oil separator so without this you should get the 'old fashion 'naturally aspirated' type action. sort of suck 'n' blow thingy! as long as the bottle can give 'free breathing' to the pipe you have connected to it. this MUST ALLOW THE ENGINE EASY BREATHING. with no restrictions.
    Sodding Typical on Sea
    I posted a similar question post to this yesterday as I knew it worked on Jeep's 2.5 and 2.8 VM CRD diesels.
    Is this a valid option then as I would gleefully buy a pretty little stainless steel trap and fit it if I can remove the EGR issues associated with the engine, I also reckon that the final emissions level would be significantly lower without the hydrocarbon injection from the original system.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    This has been discussed with myself and other members before, And the only foreseen problem is!, if you do this the ''catch tank'' must be ''free'' to breathe and 'must' be placed in a position where its fumes/odors will not enter the engine bay, they will be sucked into the heater/ blower system and you will get these 'smells' drawn into the cabin area.
    So if you do the traditional method of venting to this catch can, but then routing the pipe back to the intake closing the sealed loop?
    I would then fit one of these
    http://cgi.ebay.co.uk/UNIVERSAL-POLI...#ht_2922wt_994
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    Quote Originally Posted by Derek Mc;1250893[B
    ]So if you do the traditional method of venting to this catch can, but then routing the pipe back to the intake closing the sealed loop?[/B]
    Could you explain a little more please, do you mean differently to the top post?
    kings lynn, norfolk
    If you do vent it to the oil catch tank then back onto the intake system you will still get smoke and very hot air going back into your engine and you want cold air that's why you have a intercooler so it's best just venting it to atmosphere so you have only fresh air going onto your engine and all the oil being caught in the catch tank or bottle on my case and the hot smokey air can escape into the air and not back into engine
    Quote Originally Posted by CHRISK View Post
    I was looking at the "generic oil catch can it has an atmos, filter on it plus and inlet and outlet so, if instead of blanking one pipe as you have at the minute, taking twin pipe's one for each connection and re routing the pressurised vapour back again after the oil has dropped out, it would complete the cycle?
    Maybe maybe not I was just looking at the way they were plumbed in to the Jeeps and the end result is just as you, less (well almost no) build up in the egr system intercooler and intake.
    Derek
    By the way I am in no way taking away from your concept I think it's genius as the oil is acting as a binding agent in the egr and manifold presently in 99.9% of every Common rail diesel engines on the road, this was a proven method used by Jeep owners all over the world with amazing rates of success, and I for one will be looking to replicate this on my very own car after the three year warranty runs out.
  1. oil catch tank
    By spidermonkey in forum Diesel Engine related
    Last Post: 6th June 2012, 11:04
  2. Oil catch tank.
    By thefibreguy in forum Engine & Drivetrain
    Last Post: 7th March 2012, 15:21
  3. oil catch tank
    By spidermonkey in forum Engine & Drivetrain
    Last Post: 16th August 2011, 14:40
  4. can i put a catch tank on my vectra 1.9 cdti
    By turbo diesel in forum Diesel Engine related
    Last Post: 7th December 2010, 21:51
  5. Oil catch tank 2
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 30th May 2010, 20:52
vectra c eds oil trap
1.9 cdti oil separator
vauxhall 1.9 cdti 150 turbo oil catch tank
z19dth oil catch
z19dth oil catch tank
pic of air flow system on vectra c z30dt
mods Z19DTH
1.9 cdti oil return pipe leak
vectra c oil catch can diesel
diy crankcase oil catch vauxhall
Vectra C oil catch mod
1.9 cdti oil separator lines
vectra 1.9 cdti oil catch tank
EDS car breather mod
1.9 cdti breather mod
vectra cdti dipstick blew out
vectra c cdti crankcase breather system diagram www.vectra-c.com
diy make a diesel engine breather oil separator
eds breather mod
vectra c z19dth breather mod
Vauxhall 1.9 cdti oil catch can
eladó opel vectra c 1.9 cdti oil separator
