Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: the good and bad of the 1.9cdti engine?
    HULL
    Question the good and bad of the 1.9cdti engine?
    what are the good and bad points of this engine..the 150 version?
    i hear they pull well and respond to a remap brilliantly. but are they reliable at the same time?
    so whats the good and the bad things about these engines?
    thanks,H
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Good things, very tunable, smooth and economic.
    Bad things, DMF's, Swirlflaps, EGR's
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Seriously?! lol
    There's thread after thread on them!!
    Good points in summary -
    good power and drivability
    easily tunable to over 200bhp
    easy enough to work on (IMO)
    bad points in summary -
    swirl valves
    3rd injector wiring
    dmf problems
    alternator
    HULL
    whats the swirlflaps...lol
    i know the other 2
    HULL
    Quote Originally Posted by RobW View Post
    Seriously?! lol
    swirl valves
    3rd injector wiring
    dmf problems
    alternator
    yep...lol
    thanks m8
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    The swirl flaps are on the inlet manifold. The bar that controls them can fall off and the only real solution is a new inlet manifold
    HULL
    ahh ok i see..thanks
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    As said:
    EGR Valve - can cause poor low down performance
    Swirl flap issue - Can cause poor drivebility
    3rd injector loom - can cause the engine to eventually shut down - very dangerous actually
    Dual Mass Flywheel - Can start to rattle - left long term this can start to damage the solenoid and starter motor.
    And in issue that seem to be surfacing (and apparently can be solved for £4) - Turbo vacuum hoses can split causing poor performance.
    To be honest it is the the usual you could be buy a lemon or buy a peach.
    Personally I dont rate this engine's reliability but performance wise its a gem.
    Gazza4
    Wales, UK
    But! lol I think post 2007 models have a revised inlet.
    Am I right ?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by mark_647 View Post
    Am I right ?
    Yep July '07 actually
    Gazza4
  1. Good old 1.9cdti - start up and idle problems
    By danny_n in forum Engine & Drivetrain
    Last Post: 13th October 2012, 17:35
  2. Engine Starting 1.9CDTI 150
    By chewy71 in forum Engine & Drivetrain
    Last Post: 4th October 2010, 23:05
  3. 1.9cdti dmf change - good place??
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 30th April 2010, 18:32
  4. 1.9cdti engine
    By sealandroader in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2008, 21:05
  5. 1.9CDTi Engine oil?
    By Little John in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2007, 21:17
