Thread: DPF operation
    Sodding Typical on Sea
    Default DPF operation
    OK bit ignorant on the way these work can anyone explain what they do how they do it and how often they self clean as I am very aware of several low mileage diesels that have clogged up the filter and required it to be manually cleaned or worse replaced
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    52,000 miles later I'm still unaware of the DPF operating.............and I have one on an estate...
    Mine generally cleans itself once a tank - you can notice it by the fuel consumption going up to 1 gallon per hour at idle and your average while driving is double what it usually is. Burns for about 10 minutes then stops...
    The idea is that it injects extra fuel into the engine/exhaust (not sure exactly) to increase the exhaust temperature and burn off the soot that accumulates on the filter. It's all down to emmisions regulations, nothing at all to do with the engine itself. If you don't let it clean itself then it'll clog up completely and won't allow any exhaust gas through at all...
    As long as you give it a regular blast you should be fine - but if while cruising your economy sudenly nosedives, that's what it is...
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    The regeneration will only start when the engine is fully warmed up and you hit 3000 rpm you will notice it by the fall off in consumption, the glow plug light used to flash but that was software modded out because too many were being returned as faulty when they weren't, once its started best to let it finish as it will stop when switched off but won't automatically restart until it feels like it.
  1. operation retro
    By Даниил in forum Vectra C / Signum Car Chat
    Last Post: 26th February 2015, 00:00
  2. Someone confirm fan operation - please !
    By JagRigger in forum Electrical & ICE (including SatNav)
    Last Post: 5th July 2012, 23:15
  3. LPG operation
    By rich r in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2012, 10:44
  4. Operation Rattle-Stop!
    By DNS in forum Vectra C / Signum Troubleshooting
    Last Post: 20th August 2011, 20:40
  5. Operation Flashpoint2
    By Big-Pete in forum Games Room
    Last Post: 4th November 2009, 16:41
