Thread: Wheel nuts
    Nov 2009
    Northumberland
    Default Wheel nuts
    I've just bought some Vauxhall alloy wheels for my Vectra which currently sits on steels, are the wheel nuts the same between Vauxhall alloy and steel wheels?
    Ashington, Northumberland
    No you will need proper alloy wheel bolts as the pitch of the shoulders differs.
    11 Post(s)
    So how come you don't need different bolts when fitting the space saver then?
    What is the space saver for? For travelling at a maximum of 50mph and going straight to get your tyre sorted. It isn't meant to be a permanent fitting. Your alloys are
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Which do you have... these are the ones you need...
    M12X1.5 - 27mm long tapered bolts
    11 Post(s)
    Regardless with a space saver where you're only supposed to do 50 mph max, it will still do a lot of damage if it were to come off, so I can't see how the bolts are different for steelies and alloys.
    Some cars however do have different bolts for fitting the space saver / spare wheel (I think the Merc A class for instance).
    Also some of the Vauxhall locking wheel bolt kits state they're suitable for alloy or steel wheels.
    You may well be right. Google it and check
  1. Wheel Nuts
    By paulvectrac in forum Handling & Braking
    Last Post: 18th August 2011, 07:21
  2. wheel nuts
    By 06 vectra in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 16:36
  3. wheel nuts
    Last Post: 5th February 2008, 19:28
  4. wheel nuts help
    By surreyl31 in forum General Chat
    Last Post: 30th July 2007, 20:16
