Thread: LS suspension
    Nov 2009
    Northumberland
    Default LS suspension
    My 54 plate 1.8 LS drives like the Ark Royal so been looking into uprating the suspension. I'm not bothered about lowering it, so wondered whether it is possible to fit SRi springs and shocks to lessen the body roll? The other option I've considered is Bilstein B4 shocks with standard springs. Can anyone advise whether either of these would work?
    Wales, UK
    You can easily fit SRi shocks and springs but these will lower the car. It will only be 15mm or so lower but it does look better, it sits just right.
    WGAF#5
    the B4's are classsified as oem replacement but much better than stock shocks if your considering sri springs you would be better placed buying a set of eibach pro's which will lower by 30-40mm and are significantly cheaper than buying a set of vx springs
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Just fitted b4's and Eibach pro's all round. Normal driving shows no difference in comfort to SRi set up but put it into a bend and the new set up is leagues ahead mate. LMF are your best bet if you want to buy all together.
  1. suspension
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2011, 13:40
  2. Suspension knocking? Will Vec c suspension fit a Siggy?
    By shane5861 in forum Handling & Braking
    Last Post: 6th May 2011, 14:20
  3. DTi suspension v CDTi suspension
    By jamesy in forum Vectra C / Signum Car Chat
    Last Post: 3rd March 2011, 19:02
  4. Replies: 5
    Last Post: 21st March 2010, 12:34
  5. suspension!!
    By leonvectrac in forum Handling & Braking
    Last Post: 11th September 2008, 23:20
