Thread: Head Unit, Am I Missing Something?
    Regular Member bigdave1701's Avatar
    York
    Default Head Unit, Am I Missing Something?
    I bought a set of head unit removal keys from ebay but they dont seem to remove the head unit!? am I missing a trick here or are these completely wrong?
    *EDIT*
    Before you ask, YES i have removed the the allen key grubs.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    The stereos can be very tight mate, if you remove the heating panel under the stereo you can push it out with your finger
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Also pull the keys slightly to the sides as you pull on them !
    Regular Member Robsey's Avatar
    North East Cheshire
    23 Post(s)
    Trim : Energy
    Mileage : 131,000
    Double Din Vauxhall head-units are renowned for being tight in their cages...
    Typical How 2 remove the head unit is...
    Insert Double din removal keys until they click into their locations.
    Whilst pulling the keys slightly outward (to the sides), draw the radio out of it's location.
    Alternatively...
    Pull the large centre knob of the air-con control panel..the panel will unclip from the dash panel.
    then..
    Use the face plate flange of the radio to help to pull the radio out.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    I normally pull the centre vents and screen out, you can get right in behind the unit then to help "convince" it to come out whilst making sure the keys are in.
    Regular Member alzsxi's Avatar
    Maidstone, Kent
    I did the same as Ian, removing them also helps when installing the new headunit so you can feed all the cables properly.
    Regular Member jordib's Avatar
    Londonderry/Dundee
    how do u get the vents out? that wud make it alot easier lol
    Regular Member sdnatlst's Avatar
    Nov 2009
    Cambridgeshire
    just take the hazard button off from the dash (pops out)
    u can then lever a screwdriver on the front of the radio to push it out.
    thats how i done it, and i wasnt even using keys
    Mar 2007
    North East
    Quote Originally Posted by jordib View Post
    Pull the trim off that's above the glove box, starting at the glove box end, remove the torx screws which hold the vents and screen in position and ease out.
    WGAF#5
    took the multichanger out on mine for added "purchase" just be careful you dont pull the door off
  1. Which head unit ?
    By Mike1975 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2012, 10:38
  2. New head unit
    By fa1ska in forum ICE Gallery
    Last Post: 11th January 2011, 11:13
  3. Which head unit ?
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2007, 19:38
  4. head unit
    By fixerman in forum Electrical & ICE (including SatNav)
    Last Post: 11th August 2007, 21:47
  5. New Head unit
    By IBarfoot in forum Electrical & ICE (including SatNav)
    Last Post: 1st April 2007, 09:40
