Thread: Airflow meter fault
    Buckinghamshire
    Default Airflow meter fault
    My 2.0 DTI wont rev past 2500 and plugging in the tech2 revealed a airflow meter fault.
    I've replaced this today but still have the problem. Does anyone know if the fault requires resetting before the car will come out of 'limp home mode'?
    Any ideas welcome.
    Dave
    WGAF#5
    the car will need a few (about 20 iirc)clean starts to remove the recorded fault or if you have the radio pass - you could disconnect the battery for 10-15 minutes to clear it out - but you would also loose fuel average settings and trip etc...
    Buckinghamshire
    Will disconnect the battery tomorrow morning. Thanks for the advice.
    Dave
    Regular Member LADmachining's Avatar
    Hampshire
    If the EM light is till on and the engine still in limp mode, then the problem hasn't been solved!
    If it had, the EM light would be off, but the code would still be stored as a 'Not present' fault. It would clear automatically after a number of fault-free ignition on/off cycles, as mentioned by another person.
    Regular Member paul wingnut's Avatar
    durham
    Vehicle : vectra sri 150
    Engine : 1900 cdti 150
    if you had tc of po100 this could be brought on by a split turbo hose have a look at pipe from turbo to intercooler the one on top of engine under cover feel around even under pipe common to split also check pipe to throttle housing ..
  1. Signum air flow meter fault 2.0t
    By kirby in forum Engine & Drivetrain
    Last Post: 14th October 2011, 00:16
  2. Airflow meter
    By morrisseyno1 in forum Vectra C / Signum Troubleshooting
    Last Post: 16th August 2011, 17:25
  3. Vec C Cdti (150) Airflow Meter
    By DeanF in forum Parts for sale
    Last Post: 25th June 2009, 22:34
  4. Drivers door module and airflow meter 3.2 for sale
    By poves in forum Parts for sale
    Last Post: 6th May 2009, 21:19
  5. Removing the mesh gauze around the airflow meter
    By bobby-tupper in forum Vectra C / Signum Car Chat
    Last Post: 2nd December 2008, 19:42
vectra c 2.0dti air mass meter faults www.vectra-c.com
