Results 1 to 10 of 20
Thread: 1.9cdti 150 EGR valve and throttle body
    Durham
    Default 1.9cdti 150 EGR valve and throttle body
    Hi there,
    As part of my quest to get my 1.9 CDTI 150 to run a bit better I thought I'd take the throttle body off and see if it needed cleaning.
    The first pic shows the throttle body location. Pic is courtesy of the_wizard (cheers mate).
    I took it off and split it apart by removing the clips. It wasn't too dirty, but I cleaned it out with WD 40 and re assembled it.
    Link to how to clean the throttle body.
    http://www.vectra-c.com/forum/showth...+throttle+body
    When I went to put it back on I noticed quite a lot of black gunk on the intake, so I thought I'd clean that up as well. Unfortunately I didn't take a picture before I cleaned it, but I thought it might be worth showing what it looks like now.
    On the picture the blue arrow is pointing to the EGR valve. When I had this off to clean it I noticed a lot of black oily gunk in the two holes going into the manifold (red arrows). I cleaned it up, but didn't realise until I had the throttle body off what was going on behind the holes.
    The yellow arrow shows the machined face where the throttle body goes on tio the end of the manifold. Notice the holes through to the EGR, and the curved walls that come up to the level of the machined face. With the throttle body in place these walls form a channel through which I guess the gasses coming in from the EGR travel (green arrows). I'm assuming the curved shape and the gaps have a kind of swirl effect on the gasses.
    Anyway, this channel was completely full of oily gunk, all the way around, and all the way up to the level of the machined face. Everywhere there are green arrows was solid gunk, meaning that the gasses from the EGR were severly restricted.
    It took quite a bit of scraping out with a small screwdriver and spraying with carb cleaner. I put a rag just below it to catch the dirt, and there was a load of it.
    So it's definitely worth having your throttle body off and cleaning the inlet if you do the EGR clean. Even with the EGR valve working perfectly the deposits inside the inlet might restrict your low down performance.
    The screws were a bit fiddly to put the throttle body back on, and I dropped one. Heard it rattle down and stop, but after 20 minutes getting the under-tray off it was nowhere to be seen. So it's in there making friends with the torx bit I dropped when putting the Boost sensor back after cleaning that. (butterfingers!) Luckily I found a suitable spare.
    Since doing this the car ran better up to 1800 revs but there was another problem I had with a split pipe which was stopping the turbo kicking in properly. (see http://www.vectra-c.com/forum/showthread.php?t=109454)
    Hope this helps someone.
    Cheers,
    Richard.
    Durham
    Sorry I missed this of the original post. Link to how to clean the throttle body.
    salisbury
    thinking of removing throttle body to give it a good clean, is it just the 2 screws/nuts and it comes of?
    salisbury
    just seen your update which you posted while reading your orig, thanks
    salisbury
    richard did you open up the throttle body or just clean the butterfly valve as the oil in the pic looks bad! just wondering if you had the same?
    Durham
    Doug,
    There's three screws. The third one is below where the pipe goes onto the throttle body. You'll have to take the pipe off first to see it. This one also holds a small bracket which secures the wiring to the throttle.
    Careful as you take the throttle body off, I nearly lost the steel gasket down the engine.
    I've added a link to "how 2 clean the throttle body"
    Richard
    Durham
    Doug,
    The inside of mine wasn't anywhere near as bad as in the how 2, but there was a bit of oily soot on the sensor which I thought might have been doing no good, so I flushed it all out with WD40.
    Richard
    salisbury
    sorry mate, the sensor you refer to is that the boost sensor on the inlet mainfold or a sensor in the throttle body?
    Durham
    It's the boost sensor on the manifold. I was just making the point that I'm prone to dropping things. There's just one cable with a multi in connector going onto the throttle body.
    salisbury
    cheers fella, will have a go and give it a good clean and also check if i have any oil in it, where it comes from only knows but may catch it before it gets to bad. any bit of cleaning can only do good.
  1. Vectra c 2litre turbo throttle body and idle air valve , clean
    By davedave in forum Engine & Drivetrain
    Last Post: 10th September 2012, 21:11
  2. Replies: 43
    Last Post: 8th June 2011, 21:03
  3. how do you clean throttle body on 1.9cdti?
    By s2yob in forum Engine & Drivetrain
    Last Post: 21st September 2010, 22:48
  4. Arrrr!Throttle my Throttle Body!
    By boze in forum Engine & Drivetrain
    Last Post: 12th September 2009, 11:15
opel signum 1.9 cdti turbo problem
opel vectra c 1.9 cdti egr tulppaus
is it normal for oil in throttle intake on vectra 1.9 cdti
vectra c 1.9cdti 150 egr versions
opel 19cdti oil catch tank forum
egr vectra c 1.9 cdti
vectra 1.9 cdti throttle body
opel vectra 2008 inteke manifound
throttle body 1.9 cdti
1.9 cdti egr delete
1.9 cdti split inlet
1.9 cdti oil catch
vectra 1.9 cdti throttle position sensor location
