Thread: strange brake light fault
    Regular Member Bethan39's Avatar
    South Wales
    Default strange brake light fault
    Hi disconnected the battery yesterday to add some wiring i need for my rear electric window project, and now the car reports a brake light is out but both are working fine? there were no faults reported before but now it's on and won't go away?
    Full Member Big Sig's Avatar
    Are you sure they are working correctly as the vec will use another bulb if the brake one fails. When you have the head lights on and you press the brake you should have four lights lit. Two on each side. Make sure that all the same segments are lit on both sides.
    Mileage : 000
    Try changing both brakelight bulbs that should prove things either way.
    South Wales
    Good point i did ask my daughter to check for me the wife as the car now i'll check on that when she gets back it just seemed strange that it happened after i disconnected the battery! thanks
    South Wales
    Quote Originally Posted by ed taylor View Post
    Thanks Ed i'll try that if they both seem ok!
  1. Estate Rear brake light fault?
    By dv8 in forum Electrical & ICE (including SatNav)
    Last Post: 13th June 2012, 20:17
  2. Brake light fault indicator.
    By Ste89 in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2012, 18:15
  3. brake light fault (confused)
    By frigosolver in forum Electrical & ICE (including SatNav)
    Last Post: 21st January 2012, 15:34
  4. Brake light fault:-possible cure?
    By pilgrim in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2011, 09:20
  5. Brake Light fault
    By interceptor-jamie in forum Electrical & ICE (including SatNav)
    Last Post: 23rd April 2011, 21:05
