Results 1 to 10 of 15
Thread: ncdc 2013 speed signal question
    bournemouth
    Default ncdc 2013 speed signal question
    ive fitted my double din pioneer sat nav system but need to connect the speed sensor as its needs it to work but i cant find which one i need
    the stereo i took out is the ncdc 2013 so i know there is a speed signal there some where but just cant find which one it is
    bournemouth
    anyone ?????
    bournemouth
    after searching on here i found a red and blue wire and connected it to that but when i go for a drive it says im doing 3 times the speed im doing ???
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    and where did you find that red/blue wire? and where does it go? you probaly need a signalgenerator.. as it probaly need converting..
    whats wrong with your ncdc?
    bournemouth
    the wire came from what i beleave pin 5 which has a code scv
    will have a look into a generator
    theres nothing wronge with my ncdc and was working perfectly but i wanted bluetooth and dvd in the car and was offered a pioneer hd3 ii for a good price so couldnt refuse lol
    Engine : 2.2 Direct
    Quote Originally Posted by jb1kenoby View Post
    Yep thats the correct pin, but you need "signal generator" to transform it.
    its actually only neede when loosing signal.... it should be abel to calculate it while driving..
    ahh okay.. just thought you broke it (because i need one for parts...)
    I havnt gone after marked.. as i think the radio/screen will become to far down.
    bournemouth
    just did a search and the speed pulse generator part number pioneer nd-pg1is coming up as no longer avalable
    whats happening is its picking up where i am when im parked but when i start to drive its saying i could be a couple of streets over somewhere else
    Engine : 2.2 Direct
    that sounds more like you havnt placed the satnav arerial somewhere wrong.. or did you reuse your ncdc satnavn aerial?
    bournemouth
    ive used the ariel the pioneer came with and it and its picking up 4 satalites but may move it to see if that helps lol
    Engine : 2.2 Direct
    yes 4 satelites is not enough..
    try moving it around.
  1. Locating a speed signal
    By signum_rob in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2010, 18:43
  2. Any one got sat nav cd for NCDC 2013
    By driveryte in forum Electrical & ICE (including SatNav)
    Last Post: 6th July 2010, 18:36
  3. ncdc 2013 sat nav, help
    By bigbrox in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2010, 07:24
  4. Inside Roof Lights and NCDC 2013 Question...
    By n_hudson in forum Vectra C / Signum Car Chat
    Last Post: 9th October 2008, 15:22
