Thread: Help .. Rattle after fitting new pads
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    Default Help .. Rattle after fitting new pads
    fitted pads on all four corners last week , now i have a clanging noise when on rough surfaces , thing is i put the car on the ramp this mornin and removed all 4 wheels to see what was going on , cant find a thing all the calipers and pads are snug ,its doing my head in , must be brake related because when i brake on a rough surface it goes, any ideas lads or do i need glasses
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    cheap pads can rattle in the they genuine
    Apr 2006
    Wigan
    there oem (VX)
    Regular Member crespo's Avatar
    Bournemouth
    Have you put the metal clip thing on properly.?
    You know the bit that looks like a bent metal coat hanger.
    Apr 2006
    Wigan
    yea checked all springs and clips
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    i had that problem, it was the rear inner pads rattling around in the caliper., the pad design had been upgraded and i was running on the old style.. I bought some new mintex pads which had the spring on the top of the pad which helps to hold the pad snug in the caliper and no more rattling.
    Apr 2006
    Wigan
    will get it back on the ramp monday , thanks for your input fellas
    May 2007
    GLASGOW
    If u can also check the rubber seal on the piston inthe caliper, mine is torn to bits and am sure thats whats causing mine to rattle, as ive fitted vx pads and it didnt help
    london
    It is definetely the rear inner pads that rattle, had it on mine, in the end replaced them with the vx genuine as the former didnt fit well.
    Apr 2006
    Wigan
    yep it is the inner pad rattling on both sides , going to take them out and sort them next week , but if im being honest these pads were different from the others i had in the older ones didnt have that looped spring on ,they had one on the opposite side to face , never had any probs with them , im going to fit /make a shim for them if i can
  1. Help fitting front pads
    By 0114NIGEL0114 in forum Suspension, Wheels & Brakes
    Last Post: 18th March 2012, 00:49
  2. Fitting Brake Pads & Discs... Easy?
    By lew1984 in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2012, 00:04
  3. How to adjust handbrake after fitting new pads
    By dannycturbo in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2011, 23:18
  4. Replaced rear pads - But now seem to rattle in caliper!!!!!
    By siw8158 in forum Suspension, Wheels & Brakes
    Last Post: 21st August 2009, 20:05
  5. Rattle rattle boooooom!!
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2006, 08:44
