Thread: Rear brake pads
    Regular Member justyb's Avatar
    wigan
    Default Rear brake pads
    Hi guys car is going in fot MOT next saturday rear pads are getting low about 4-5mm left whats the mot limit for rear pads?
    Sodding Typical on Sea
    Should be just the wear limiter itself don't think the amount of material on the pad is in itself an MOT failure
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    1.5mm is advise/fail
    Glasgow
    As far as im aware you cant fail for low pads, it will only fail if it fails the brake test. Nothing can be removed while doing an MOT for example your bonnet has a hole in it all you have to do is put black tape over it and they cant touch the tape. So they cant take your wheel off to check the pads.
  1. Rear Brake Pads
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2011, 18:25
  2. rear brake pads
    By gdansk in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 08:21
  3. Rear Brake Pads
    By steve-wolves in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2009, 14:18
  4. Rear Brake Pads
    By cp123 in forum Suspension, Wheels & Brakes
    Last Post: 24th May 2009, 13:15
  5. Rear Brake Pads
    By CHRISSMART41 in forum Suspension, Wheels & Brakes
    Last Post: 16th October 2007, 18:22
