Results 1 to 10 of 11
Thread: What size are the brakes on the 2.2 SRi?
    Regular Member Nato's Avatar
    Risca, South Wales
    Default What size are the brakes on the 2.2 SRi?
    Am deciding which brakes to go for on the Vectra, and am considering a set of Mintex drilled and grooved discs. I don't want to order them though, and then find they don't fit!! The brakes are listed as being for the 2.2 SRi, but as they are quite costly, I don't want to make the mistake of buying the wrong size!
    Can anyone tell me what size the front and rear discs should be?
    Hanging Heaton / Batley
    19 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Risca, South Wales
    I'm looking at THESE as they have pads in the kit as well.
    WGAF#5
    Quote Originally Posted by Nato View Post
    thats the kit you need
    Full Member izonoky's Avatar
    Aug 2007
    London
    Nice, I think it's possible to fit larger discs too IIRC up to 314mm (?)
    2.2 Direct SRi
    Oct 2006
    Waterloo, Liverpool
    8 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Quote Originally Posted by izonoky View Post
    You need at least 17" wheels for the 314's though.
    WGAF#5
    and larger calipers and carriers to boot
    Regular Member Nav-Man's Avatar
    London
    Are the discs on the SRI 1.8 (petrol) the same size? How do you measure the discs, is it from side to side, or do you also have to measure the thickness?
    Risca, South Wales
    Quote Originally Posted by Nav-Man View Post
    You measure the diameter across the disc. Not sure if the 1.8 is the same size setup though, I'm sure someone will be along to confirm.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Nato the ones you linked to on ebay watch as the picture shows 4 stud pattern, the picture is most likely for show purposes to give an idea of what the discs look like but just to be sure bud.
    Gazza4
  1. What size brakes
    By BBMadness in forum Vectra C / Signum Car Chat
    Last Post: 19th October 2012, 10:10
  2. What size brakes
    By sebadee in forum Suspension, Wheels & Brakes
    Last Post: 7th March 2011, 19:22
  3. what size brakes
    By i5aces in forum Handling & Braking
    Last Post: 27th December 2009, 22:26
  4. What size brakes??
    By danBoy in forum Handling & Braking
    Last Post: 17th October 2009, 22:37
  5. what size are my brakes?
    By nev-vec in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2008, 07:52
