Thread: EGR Valve
    Sheffield
    Default EGR Valve
    Hello
    First post so be gentle.
    I have an 04 2.0 DTI Vectra Elite Estate(110K) which has the car/spanner light and car going into limp mode coming on periodically.I've had a basic diagnostic come up with "throttle mechanism negative deviation".
    When i spoke to a Mobile Diagnostic bloke(who i've used before) he said that there was no point in him coming out as it's the EGR Valve that's clogged or faulty.Common fault on high mileage diesel Vectras apparently?
    So if this is the case where exactly is the EGR located?
    Thanks in advance.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    if you have a code for the throtle body you need to check if you have a throtle valve in the top inlet manifold these have been known to go awol and give throtle codes ....if you havent got a throtle valve i would try cleaning the egr valve .if ya do a serch on here for cleaning a dti egr .....
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Hi m8 your egr valve is mounted on the front of your engine block just to the right of your dipstick and has two hose connections going into it see pic
    Have a search for egr valve cleaning on here there are a couple of how 2 ,s showing you what to do also you might as well do the boost sensor at the same time , if one is blocked up then other usually is as well.
    and still loving it
    Sheffield
    Cheers lads i'll give it a clean and see where we go from there
    Jul 2009
    barnsley,yorkshire,GB
    Engine : 20 Dti
    Hi ibbo
    it's an easy quick job,but with your milage check inside the manifold you may find that it's as bad as the EGR valve for carbon build up.
    Sheffield
    Quote Originally Posted by jonnybravo View Post
    Hi ibbo
    I'm going to do it tomorrow,thanks for all the help and advice.
  1. Brake servo Valve (one way valve)
  2. Replies: 6
    Last Post: 29th July 2012, 13:52
  3. Egr valve, swirl valve problems etc..
  4. EGR valve / Swirl valve
    By SwavGav85 in forum Engine & Drivetrain
    Last Post: 5th January 2009, 17:17
  5. EGR valve and Swirl Valve
    By TUX-VECTRA in forum Vectra C / Signum Troubleshooting
    Last Post: 6th July 2007, 00:43
