Thread: flashing L E D headlights
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    Default flashing L E D headlights
    does anyone no how to stop my led angeleye headlights from flashing as its failed the mot .p.s they flash all the time when the lights are off.can change back to standerd bulbs but its a pain in the ass to do as there are 16 to change. cheers . luke
    Aug 2009
    Regular Member badback's Avatar
    Runcorn
    I think you'll need resistors mate, but I haven't a clue which ones, here's a page on ebay that has them, good luck with it.http://shop.ebay.co.uk/?_from=R40&_t...All-Categories
    Jul 2009
    The Rift, Cardiff
    You can take a wire from the cigarette lighter socket illumination, through a relay and replace the side light wire with it. They'll then come on when you switch the side lights on and best of all they'll come on when you press the key to unlock the car.
    To cancel the bulb warning you can either use a resistor or just use a 501 bulb hidden away/capped.
    Aug 2009
    cheers for your help lads
    Cambridgeshire
    surely a resistor wont help the flashing? it will get rid of bulb warning but because of the vecs self electric circuit test thingy it wont stop the flashing when car is locked or unlocked or sidelights switched off after being on or drivers door being opened ect ect??
    i may be wrong??
    saying that i had a idea the other day, could you fit a capacitor before the leds and that will store the vecs system check charge rather than lighting up the leds??
    it would take a few seconds on switch on for the sidelights to respond as capacitor needs to fill up but after that??
    reason i was told they flash is the system check current is enough to light leds but not bulbs?? leds only need 0.6v to light???
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Quote Originally Posted by ChrisBilly View Post
    This is the best way... but you can also take the feed from the heated rear seat illumination (green and a brown blocks/yellow grey wires) under the rear lighter socket - if you have them it'll save you messing with the lighter socket illumination as there usless anyway... Unless you have heated seat of course
  1. Seperately Flashing Police Headlights?
    By john506 in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2011, 22:39
  2. Flashing headlights and electrics problems?
    By robshortman in forum Electrical & ICE (including SatNav)
    Last Post: 23rd December 2010, 23:39
  3. flickering flashing dash and headlights
    By in7ox in forum Electrical & ICE (including SatNav)
    Last Post: 6th May 2010, 21:45
  4. flashing hid headlights
    By callum in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2010, 01:25
  5. headlights flashing
    By Darren68 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2009, 11:09
led headlights flashing vecrra c
why do my led headlights flicker vectra c
vectra c led headlights
