Thread: modified hose fixed turbo lag and no power cdti
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default modified hose fixed turbo lag and no power cdti
    If you look at the cdti 150 turbo not boosting thread in here I have put up pics and explaination of the turbo lag and no power low down probs I have had and how I fixed it too just incase you guys have it even if not then the cost of doing it is 4quid and worth it just for peace of mind
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Tell me more.....is the one with the clear tube's?
    Winteringham
    come on how did you fix it
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Regular Member storm's Avatar
    Northumberland
    what size are the pipes?just looking at blue ones on the bay and unsure of the size
    Regular Member Fash's Avatar
    Doncaster
    hmmm, can't help to change the pipes as a preventative measure....I too would like to know the size if poss please so I can order a replacement pipe to cut into two or more, and blue would be great (is it 4mm??)
    kings lynn, norfolk
    Hi guys sorry for the delay I am pretty sure it's 4mm inner diameter I used and just put cable ties on to keep it all tight belt and braces I also used hot water to soften the pipes to push on hope that helps and report back your findings
    Northumberland
    cheers winnie will do mate
    Regular Member kev77's Avatar
    nottingham
    Default blue pipes fitted
    fitted today 4mm internal diameter perfect fit
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    We really don't need a number of threads on this subject when the main one is a sticky so I am closing this one
  1. Replies: 23
    Last Post: 17th November 2012, 23:49
  2. Replies: 30
    Last Post: 28th August 2012, 08:35
  3. 3.0 CDTi turbo hose
    By irn_bru_ce in forum Engine & Drivetrain
    Last Post: 21st July 2012, 12:43
  4. cdti 150 turbo lag fixed
    By Graeme01 in forum Engine & Drivetrain
    Last Post: 29th June 2010, 08:30
signum 3.0 cdti turbo lag
