Results 1 to 2 of 2
Thread: Drive Shaft Gaiter
    Sheffield
    Default Drive Shaft Gaiter
    Just had an advisory on MOT OSF Inner drive shaft gaiter is leaking grease,does anybody know roughly how much to replace at a garage.
    Car is 2004 2.2DTI Estate
    Regards Steve
    Regular Member DaveW555's Avatar
    Cannock
    It depends really if the gaiter is spllit (new gaiter) or if the clip has just come off? If its just the clip you could probably just put a cable tie round it and job done, however if the gaiter is split the driveshaft will have to come out which means draining the gearbox oil, dropping the bottom arm and removing the shaft itself, the gaiters themselves are only a tenner tops its just a bit more labour intensive with it being the inner one.
  1. Drive shaft
    By drummo in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2012, 13:50
  2. hollow thumping noise & split drive shaft gaiter
    By cavalier_attitude in forum Suspension, Wheels & Brakes
    Last Post: 2nd August 2012, 14:41
  3. drive shaft
    By andy treg in forum Troubleshooting
    Last Post: 5th May 2011, 17:04
  4. drive shaft
    By glynn in forum Vectra C / Signum Car Chat
    Last Post: 4th May 2008, 12:44
