Results 1 to 10 of 13
Thread: HIDS fitted
    Milton Keynes
    Default HIDS fitted
    Well i finally fitted my hids, bit of faffing with the bulb holders, that literally was the longest part of it, had them working, so closed everything up, then they started to strobe.... not happy ... so took the airbox back out, windscreen fluid pipe, wasn't really sure why it was doing it but I disconnected the extra capacitors, it came with the two large ones and then two smaller ones, took them out and there working tip top (so far).....
    If you don't have these already I urge you, go get them NOW... NOW... NOW... there immense, best mod i've done, the difference is just unbelivable, if your undecided, umming and arhing, just do it! I have the 35w 6000k from HIDS direct...
    http://www.hids-direct.co.uk/hid-con...its-p-443.html
    Piccys......... they dont do them justice
    Michael
    milton keynes
    Very nice mate , did mine a few weeks back . Standard lamps are like candles in comparison
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    one of the best mods to do to your vec you wont regret it
    Regular Member Bethan39's Avatar
    South Wales
    Quote Originally Posted by neverlandandy View Post
    Here here makes so much difference!!
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    I may need a different kit, Facelift being full canbus, can't find them on link
    lanark
    5 Post(s)
    Year : 2012
    Mileage : 9k
    this is what you want for your facelift thats what i have on mine with 6k
    http://www.hids-direct.co.uk/hid-con...its-p-445.html
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Thanks for that. Does it need to be 50w? Was thinking of 35w 4300k H7's, not fussed about colour, just want to see where I'm going. Standard dip beam halogens were dire, main beam ok
    11 Post(s)
    Quote Originally Posted by Grumpy1954 View Post
    I fitted this kit to my facelift - no probs so far with it.
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Yes, that's the one I was looking at, but then this thread started with a different company link. I pretty much want to fit and forget and have it work reliably. Think I may stick with this one when I get one.
    What did you have before? standard or upgraded? how big a difference do they make? as good as they say?
    11 Post(s)
    Originally the factory fitted halogen H7's and H1's. I then fitted Osram nightbreakers, but the dipped H7's only lasted approx 8 months before failing one week apart from each other. Vast improvement fitting the 35W 6000K HID kit and also using Duncan's suggestion of adjusting the lights as they were set too low. I made the height adjustment while I had the nightbreakers fitted.
  1. HIDs fitted!!!!!!!
    By Das in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2012, 17:38
  2. HIDs fitted
    By RobertHayman in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2011, 22:34
  3. New HIDs fitted
    By suggs1971 in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2010, 20:49
  4. HIDS fitted
    By slick91 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd April 2010, 08:26
  5. HIDs fitted........
    By fingers66 in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2010, 17:09
