Results 1 to 10 of 30
Thread: De-lock Drivers Door...
    Hanging Heaton / Batley
    21 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    Default De-lock Drivers Door...
    What would be the best way to go in an emergency situation...
    Running a second bonnet pull down to the front or an arch etc (hidden obviously)
    Or run a power lead off the battery so i can jump it should battery die??
    What other ways round it would you recommend?!? (other then not doing it )
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Dont know if its me, but havnt got the foggest clue what your asking?
    Regular Member benny's Avatar
    Feb 2006
    dudley
    go down the vxr peps route ...the open and start system i think they had a handle with a hidden normal key
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    with my old megane you had to put the key under the cap and pop it off to get to the lock if the remote didnt work
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    If your battery runs flat and you can't unlock the car to pop the bonnet.... get underneath and use jump leads... negative to a decent chunk of engine... positive to nice big positive lead on starter motor..... that should quickly allow sufficient power to allow central locking to be zapped open.
    21 Post(s)
    Mileage : 110k
    Quote Originally Posted by Graham View Post
    Sorry, i'm planning on removing the lock stub (from the drivers) and fitting a blanking stub instead.
    But if the battery on the car goes i'd be screwed - So the 1st post are my only ideas at the min to gain access to the car
    21 Post(s)
    Mileage : 110k
    Quote Originally Posted by Handyandy-UK View Post
    Thats what i was thinking, + lead feeding down to behind the foglights... Or a short bonnet catch wire...
    But which is better - any other options...
    coatbridge
    are you delocking the boot ?
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    By 'lock stubb' do you mean the lock barrel ?
    Not the cleverest of ideas I'd have thought..... batteries go flat... lock motors fail.... zappers die..... the key might well be your last hope.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Quote Originally Posted by marty_b0y View Post
    You beat me to it mate.
    I de locked my Pug 306, all I did was run two wires down behind the fogs with the other ends connected to the battery. Make sure there well insulated and cant short and bob's your uncle. But as said, your boot will be the same as mine with a lock so your could just go through there. Or to be really flash, fit the lock barrel inside and underneath the mirror housing, obviously it wouldn't pop the drivers lock physically but it would pop the central locking so you could get in the passenger door.
  1. drivers door lock
    By eddy b in forum Vectra C / Signum Troubleshooting
    Last Post: 20th September 2011, 06:24
  2. Drivers Door Lock Switch Help
    By UltraVec in forum Electrical & ICE (including SatNav)
    Last Post: 27th June 2011, 16:31
  3. Drivers Door Lock not working
    By Rupster_69 in forum Vectra C / Signum Car Chat
    Last Post: 2nd June 2011, 16:07
  4. Drivers Door lock problem
    By r3m0dul8 in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd December 2009, 10:43
