Thread: woodruff key
    Regular Member Graeme01's Avatar
    Aug 2009
    wirral
    Default woodruff key
    anyone know the size of the woodruff key from the feul pump sprocket off the 1.9 cdti engines as i may have misplaced mine lol
    anyone changing there manifold tht can measure it would be a massive help
    cheers
    Regular Member benny's Avatar
    Feb 2006
    dudley
    sorry mate you wont find one anywhere .....i lost one years back and did struggle to even find someone that might have one ....either new pump or 2nd hand .... but um i would say leave it out .......
    4.0mm(W) x 16.0mm (L) x 6.5mm (H)
    There's a guy on eBay sells the for pennies here
    The length value varies depending on which measurement the seller quotes, some quote the (L) figure as the actual length of the key, others quote the (L) as the diameter of the key if it were a full semi-circle.
    As long as you get 4.00mm(w) x 6.5mm(h) it will be correct.
    All the best
    Pub
    Also, have a LOOK HERE
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    vx will sell you one or be care full and don't drop it
    Aug 2009
    wirral
    Quote Originally Posted by pubsinger View Post
    All the best
    Pub
    cheers mate just replied on your other post but thanks frot he help mine is 6mm height but im not arguing over 0.5mm lol
    Quote Originally Posted by mattv6diesel View Post
    thanks for your help mate take it you have changed ya manifold ?
    already been to vauxhall was first place to try and didnt fancy paying 700 for a fuel pump just becuase i need the woodruff key
    My House
    Hi mate,may have one at work but not in until monday so will check for you then.
  1. Camshaft Woodruff Key
    By 123rado in forum Engine & Drivetrain
    Last Post: 2nd January 2013, 22:54
  2. Woodruff key
    By mparks8590 in forum Engine & Drivetrain
    Last Post: 28th September 2010, 14:20
1.9 cdti woodruff key
