Results 1 to 3 of 3
Thread: Not Vectra but Corsa clutch problem.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Default Not Vectra but Corsa clutch problem.
    Guess this is the wrong section but here goes......
    My daughter's V plate 101k mile Corsa manual seems to have a clutch issue.
    The bite point is about 1" off the floor which, as she's learning to drive, is making life rather difficult for her.
    I thought that when a clutch was on its way out, the bite was very near the top of the pedal stroke, not the bottom.
    So is her clutch cream crackered or something else more sinister?
    Do you mean that it is just 1" from the floor, ie you have to press the clutch all the way
    If so, that is quite normal on a clutch near the end of its life, however may simply need adjusting
    Put the car in reverse and see if the back of the car rises, if it does the clutch is indeed near the end of its life
    New cars usually need very little clutch pedal movement
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Sounds like just the clutch cable needs adjusting. Is the clutch pedal lower than the brake pedal?
  1. Help. vectra c clutch problem
    By bucco in forum Engine & Drivetrain
    Last Post: 8th February 2013, 20:00
  2. Corsa C - Weird central locking problem
    By damers2000 in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2011, 17:28
  3. daughters 52 plate 1,2 corsa problem
    By tonyord in forum Engine & Drivetrain
    Last Post: 3rd March 2010, 21:15
  4. corsa d recalls?? and clutch judder
    By vectragsi3.2 in forum Vectra C / Signum Car Chat
    Last Post: 1st August 2008, 22:20
  5. Corsa problem
    By Karl in forum General Chat
    Last Post: 27th July 2007, 19:04
