Page 1 of 6 123 ... LastLast
Results 1 to 10 of 59
Thread: 2.0 CDTi 160 v 1.9 CDTi 150
    Aug 2009
    Bristol & Stockton on Tees
    Default 2.0 CDTi 160 v 1.9 CDTi 150
    Is the new 2.0 CDTi 160 based on the old 1.9 CDTi engine, and hence subject to all of the same problems with choking / sticky EGR valves, swirl bar rods falling off e.t.c. ?
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    it's a development of the old engine from what I gather, but you can rest assured you won't get any of the same swirl valve problems as before.
    Even vectras after 2007 had a revised manifold design that appears to have eliminated the trouble (which wasn't as common as we're led to believe on this forum anyway).
    Leicester
    There was not many 1.9 16v's that suffered from EGR faults though. I had 4 of them and they were all fine.
    It's pretty much the head and block thats carried over with some re-work, after looking at my 2.0 CDTi 160, everything else all looks a different design.
    But the engine is fine with no reported faults from dealers at all!
    Regular Member grumpano's Avatar
    North West
    I find the 160 engine pulls better at low revs and doesnt seem to suffer from the turbo lag the 150 did. But me and the wifey both think the engine is noisey compared to the 150 at low speeds.
    It also idles at a higher speed(1000 revs) untill the car comes to a halt ,then it settles at about 900 revs.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    Quote Originally Posted by Hideous View Post
    pmsl how wrong could you get ....the 160 is a totaly different set up regarding the inlet manifold / egr ...but there still **** ...seems the swirl problem has started to creep in and there is a egr recall out on them and there is also a dpf recall out ....lol at least the vec waited a while before throwing its toys out ....
    Leicester
    Quote Originally Posted by grumpano View Post
    Mine idles at different revs also, I believe it is down to the state of charge of the battery and the idle adjusts accordingly.
    Quote Originally Posted by benny View Post
    Is there any reason to be a total arse the way you correct people? There are ways and means of saying to someone there information is incorrect without the way you wrote it.
    Also, the engine is not **** as you put it. I have had no issues with mine in the 5000 miles I have done so far, then again my 1.9's were ok as well.
    So what do you drive then Benny? Suppose it's fantastic!
    North West
    Got to say Matt your spot on with Bennys comments.My CDTI had 60000 miles on the clock when i sold it. And it without doubt was the best and most reliable car i have ever had.
    Oh and ive had a few in my 47yrs.
    Cars as well
    Quote Originally Posted by Maverick View Post
    Isn't he a VX Tech though so should know these things inside out?
    Regular Member alanv6's Avatar
    Nov 2007
    weymouth, dorset
    Think he is like me, but as soon as we say somthing nasty about a 1.9 or an insignia we get our eyes gouged out in a cat fight..
    You agree with him then? Have you seen many faults with the new insignias?
  1. Weird noise from Signum CDTI 1.9 CDTI (150)
    By oneightycd in forum Diesel Engine related
    Last Post: 22nd June 2007, 22:27
  2. CDTi 120bhp Vs CDTi 150bp
    By bennyk in forum Diesel Engine related
    Last Post: 6th December 2006, 23:45
  3. CRD2 Tuning Box for V6 CDTi or 1.9 CDTi
    By The Doc in forum Parts for sale
    Last Post: 20th October 2006, 21:51
opel vectra 1.9 cdti vs 2.0
1.9 cdti czy 2.0 cdti
will a 1.9 cdti block work with a 2.0 cdti head
1.9 cdti block same as 2.0 cdti block
is the.2.0 cdti head the same as a 1.9
does a 1.9 cdti block fit a 2.0 cdti head
what the difference between 1.9cdti and 2.0cdti
difference between 1.9cdti and 2.0cdti head
vauxhall 2.0 cdti engine
