Thread: mot big failed
    Regular Member luke.oldham's Avatar
    Aug 2009
    manchester/stockport
    Default mot big failed
    just pick my car up from the mot and O M G he told me not to drive it till it gets sorted. theres springs snapped wheel bearing is nackerd he said he jacked it up and the front end is all loose.what should i do as ive just spent £400 on cambelt and water pump.i think ive spent to much on it now to get rid.do i get it sorted or is this the start of it as i only had it 9 month. cheers luke
    Jan 2010
    glasgow
    post up what hes put down on the fail sheet if hes saying dont drive it dont
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Depends what he's saying is "loose". If it's just play in the front suspension then drop links, anti roll bar bushes, suspension strut top mounts/bearings, lower arm ball joint or a few other bits are quite common.
    If he's talking about the chassis being loose then you have bigger issues.
    Aug 2009
    1 both lamps flashing when turned off. ps ive got led angeleye lights . 2 offside front coil spring cracked. 3 nearside front suspension has excessive play in lower suspension ball joint . 4 offside front suspension arm rubber bush deteriorated resulting in excessive movement . how much do you think its going to cost, cheers
    Jun 2009
    South Coast
    Vehicle : Vectra, Signum & Insignia
    Engine : Z18XE,Z19DTH,Z20NET,
    dunno about the lamps but springs can replaced with secondhand ones for about £20, the ball joint will mean a new wishbone for £60, anti roll bar bushes about £12, droplinks £15.. Nothing hard, I have done all those bits on my own car by myself (except the wishbone but i watched that being fitted and they did not charge me much to do it, less than an hour)
    All cars have things that wear out and replaced but once there done there done and your car will last longer, you can buy another car but you will do through the same thing soon enough as somebody will wanted to get shot if it like you are thinking of doing..
    The wifes vec show car is currently being stripped for parts before i scrap it, keep an eye on the sales section.. https://www.vectra-c.com/forum/garage_vehicle.php?do=view_vehicle&id=709
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    If you've got the old headlamps still kicking around, that's an easy fix, swap them back in for the MOT and back out again afterwards. Otherwise you may have issues, LED bulbs can cause all sorts of issues on the Vec C.
    Spring, again an easy fix, replace that axle's springs (always do the pair). I've got a full set of 4 standard SRi springs if they're any use to you (check your axle weights on the drivers door pillar) that you can have for £50 for the full set or you may get a pair cheaper on Ebay or something.
    Lower suspension ball joint is a bit ambiguous, it could well be the lower arm needs replacing but it could also be the drop link (a lot cheaper and easier to do) I'd seek clarification if possible.
    Suspension arm rubber bush is most likely the Anti Roll Bar bushes but again I'd seek clarification to be sure.
    Aug 2009
    thanks for your advise lads.just got some quotes its going to be around £130 ish inc labour .not as bad as i first thought. cheers. luke
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    That doesn't sound so bad, as has been said, if you're up for it you could do a lot of it yourself. If not quotes not bad.
    I spent £400 on the MoT for my 52 plate Omega last spring, wrote it off at the end of August, was I gutted or what!
    Regular Member DaveW555's Avatar
    Cannock
    Cant believe you got charged £400 for the timing belt and water pump. You proper had your pants pulled down there matey. I fit them for £250 using OEM parts.
    Aug 2009
    they gave me a free cushion with it tho .coz i got my ass slapped. lol
  1. Failed MOT
    By spennny in forum Suspension, Wheels & Brakes
    Last Post: 18th April 2011, 13:54
  2. EGR Mod failed
    By Teapot in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2011, 14:59
  3. MOT failed :-(
    By byebyeitsagsi in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2010, 20:14
  4. Vec failed its MOT
    By JusSRi in forum Vectra C / Signum Car Chat
    Last Post: 25th June 2009, 19:48
  5. Tried & tried but failed doing what?
    By Tadpole in forum Bodywork & Interior
    Last Post: 4th May 2009, 19:26
