Results 1 to 10 of 17
Thread: HIDS arrived
    Milton Keynes
    Default HIDS arrived
    So my HIDs arrived today, delivered to work before I even got there, top service! Ordered 35w 6000k, questions.... are they easier than they look to fit? Drilling etc? Where can I mount my cancellers? I worry when it comes to electrics! I have a prefacelift?
    Michael
    Administrator plasma's Avatar
    On the Forum
    357 Post(s)
    Engine : 150
    Mileage : 74000
    i normally use sticky pads and mount them between the slampanel edge and wing edge... You'll see when you remove the headlights what i mean... tucked in the corner out the way. No need for drilling...
    Milton Keynes
    so when it says drill a 25mm hole in the back of the cover I dont need too? Do I need to remove the bumper and headlights etc so I can get to them properly?
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    when i fitted mine alli had to cut was a hole in the rubber cap that covers the bulbs, easy job to fit mate and best thing you can upgrade
    i removed bumper and headlights thats another easy job but people have done it with out removing them but i found it easy to,
    Regular Member axelf's Avatar
    chester le street
    Hello m8, i have done mine and 4 other peoples for them ....you dont need to take the bumper and headlights off to do the job...Remove the air box all together to do the drivers side 1....open the battery cover and twist off the washer filler neck to get in to the pass side 1.....The hole you have to cut out is on the cover (rubber boot) on the accsess for the bulbs on the rear off the light...this is so you can feed the wires through from the HID bulb...i mounted the ballast boxes in the inner wings so they wouldnt get any water on when raining.....also used the cancelors.....hope this helps....
    Milton Keynes
    Quote Originally Posted by axelf View Post
    Spot on mate.... will have a go later today, don't fancy doing the bumper removal thing,, how long should it take? Will I be able to fit the cancelors and ballast boxes with double sided tape? I have some stupidly strong stuff?
    chester le street
    At tops it will take you about 1 hr....i used that double sided sticky stuff for number plates..stuck the balles on the inner wing then stuck the cancelor on the ballast box...you could even just put the 1 on pss side in where the battery is .....loads of space and it will keep dry....
    VOTING UKIP IN AVELEY
    18 Post(s)
    Vehicle : Vauxhall
    Trim : Astra Twin Top
    Engine : 1.9cdti
    Year : 07
    yep that should be fine........I would advise that you seal the rubber grommit in as the hole for the \HID bulb is bigger than the grommit (go ftgure) ..ideally if you are good are cutting and crimping cable it is easier to do this and drill a smaller hole for the cable to pass through..The headlights have been known to mist up if to much moist air gets in there .,,,,,Also found it much quicker to take the bumper off
    Milton Keynes
    I'm sure once I've got it all out and put together it will make more sense..... Will see how it goes, So just putting a hole in the rubber cover to feed the wires through? other than that its look okay to do!
    11 Post(s)
    Under the headlights (facelift) there is a recess for the ballasts to be fitted. Not sure if the same applies to prefacelift.
  1. I've arrived!
    By amarley in forum Introduce yourself.
    Last Post: 16th January 2013, 14:21
  2. Look what arrived (what's in the box :))
    By Hyperhart in forum Vectra C / Signum Car Chat
    Last Post: 13th June 2012, 23:29
  3. Its arrived
    By amos in forum Insignia car chat
    Last Post: 1st June 2009, 07:18
  4. It's Arrived!!!
    By Mark The Cabby in forum Insignia car chat
    Last Post: 7th April 2009, 22:09
  5. look what has arrived
    By darko2301 in forum Styling
    Last Post: 9th March 2009, 11:33
