Results 1 to 10 of 18
Thread: egr blanking plate
    Regular Member Graeme01's Avatar
    Aug 2009
    wirral
    Default egr blanking plate
    im in the process of changing my inlet manifold and form looking at the state of the part the egr valve bolts to its quite clear where the crud is coming from! I have heard good things about blanking off the egr valve but cant seem to find the blanking plates anywhere!
    does anyone know where i can get them from?
    cheers
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Have a search for Fiat Gaskets mate, I have posted the part numbers before from a Fiat dealer.
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Or just make your own from some aluminium plate or even a coke can that's what I done cut around the gasket to get the shape and I drilled just a 5.5mm hole in the middle and I have no eml on and runs perfect it cost me nothing and it's alot more restrictive than the 4holes in the fait ones
    Also alot of the crud comes from the oil breather pipe that feeds back into the manifold which is where all the oil sludge build up comes from
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Quote Originally Posted by winnie2457 View Post
    I made one from 1mm stainless but it was hard work to cut & drill so I think the aluminium or coke can is the way to go.
    I started with with an 8mm hole but got both eml lights coming on intermittently but after drilling it out to 10mm all is well - every engine seems to want something different but most agree that the CDTi runs better with blanking fitted
    Lancashire
    Trim : XP1
    Mileage : 66000
    Which one is this bud..?
    Regular Member Vaux-Man-G's Avatar
    Birmingham
    Interesting about the breather holes....tell us more
    woking
    shout at me if u must but i just dont get it why is the egr there if it runs fine without it?
    Lancashire
    Trim : XP1
    Mileage : 66000
    Quote Originally Posted by lgtuk View Post
    Euro emissions, purely so they can release the car, other than that, sweet F.A !!!
    If only the CDTi allowed us to remove it and blank it like the BMW units can
    Birmingham
    Quick one, IF I unpluged the EGR Valve, naturally it would throw a wobbly and illumintate the EML....apart from that, should I see any difference, will it go into Limp Mode?
    Im just thinking, IF I try to drive without it connected, surely this shoudl determine if the EGR is scrooged or not?
    woking
    mine clogged completely and went into limp mode so surely blanking it off all together is going to do the same??? does it effect fuel or performance to the car blanking it off?
  1. For Sale: DTi EGR Blanking Plate
    By TonyP2020 in forum Parts for sale
    Last Post: 8th November 2012, 00:10
  2. Egr blanking plate
    By morrisseyno1 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th September 2011, 20:49
  3. Egr blanking plate
    By baz_cdti_sri_150 in forum Diesel Engine related
    Last Post: 2nd April 2011, 19:51
  4. blanking plate
    By lordreeson in forum Engine & Drivetrain
    Last Post: 3rd March 2011, 12:59
