Thread: Aircon no gas
    Sep 2009
    Glasgow
    Default Aircon no gas
    Hi all, was warm today and turned on a/c and it didn't make a difference if anything i thought the vents were cooler without it, when i got home parked up and turned a/c the revs dipped slightly and engine tone changed slightly and also heard the relay click, with engine turned off removed the black cap at offside of engine wich i think is for the air con and pressed the ball valve in with a long screwdriver, from what i have been told i would either get gas gushing out or a slow wimper of gas, but i got no gas what so ever totaly empty. The car is a 55 plate and i doubt it has ever been topped up, it is possible for the a/c to be completely depleted of gas after 5 year or is it a possible slow leak, tried to book into my local aircon today but were fully booked £35 for recharge + leak test+cleanout.
    Regular Member RobW's Avatar
    Tain - Easter Ross
    If its not been used then (AFAIK) it dries the seals and weeps out.
    Need mine done too
    Sep 2009
    Glasgow
    take it the recharge will lubricate the seals and wont need to replace them.
    Regular Member crespo's Avatar
    Bournemouth
    Take it to quikfit. It is £25 for a recharge and if it does not work because of a leak there is no charge.
    Ignore the anti quikfit jibes as it is done with a machine that a circus chimp could work so the quikfit doughnuts are more than capable of working it without damaging your car.
    Suffolk, Englandshire
    Vehicle : BMW 525i
    Trim : SE Touring
    Engine : 3.0
    Two most likely scenarios:
    1 - Through lack of use over time the seals have dried and permitted the refrigerant to leak. Low pressure switch kicks in, prevents system from running as a protection measure.
    2 - Through damage from stomes, road debris,road salts and other muck, fluff, dust and custard, the condenser has sustained damage permitting leakage of refrigerant. Low pressure switch kicks in, prevents system from running as a protection measure.
    Sensible choices to remedy:
    1 - Have system checked by a vehicle aircon specialist and act on their findings.
    2 - Attend kwikFit (or similar), have them put the car on their automatic aircon tester and if the system passes the pressure tests it will regas, you pay around £45 and all is well.
    3 - You strip and inspect the condenser yourself, replace if (probably) necessary, then attend a facilty as noted in 2, who can test and regas the system for you.
    Sep 2009
    Glasgow
    Sep 2009
    Glasgow
    sorry, can a mod please remove.
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. Aircon
    By GoldenWonder in forum Bodywork & Interior
    Last Post: 20th June 2012, 18:18
  3. aircon help
    By jimmywhu in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 01:33
  4. aircon
    By eminemme42 in forum Vectra C / Signum Car Chat
    Last Post: 3rd April 2012, 13:32
  5. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
