Thread: lowering springs and upper control arms
    Regular Member denzilbud's Avatar
    cambridge
    Default lowering springs and upper control arms
    as title how much should i be looking at to get these fitted been told an hour for each spring and an hour for each control arm at £30 an hour does this seem ok also what kind of prices will i be looking at for somewhere like quick fit to fit
    cambridge
    anyone
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Did my springs and shocks this weekend mate. Never done it before, took me an hour for the first front and then once I knew what I was doing I probably did the second it half that time and same with the back. If you have the tools its actually very easy and straight forward.
    cambridge
    thats the problem havent got the tools i did think he was taking the **** with the hour each side for the rears
    Vehicle : SRi
    Mileage : 137000
    Wheel off, caliper off, lower control arm to hub bolt off and the spring just pulls out. You don't even need spring compressors for the rear.
    cambridge
    ive read the how to for the rears thats what made me wonder as if i had the tools i cant see the rears taking me any longer than an hour for both
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The rears will only take you about 10 minutes a side, as others have said, it's just take wheel off, undo lower arm bolt, push arm down and pull spring out, new spring in, jack arm back up and bolt back in and wheel back on, you're done. The fronts will take longer and word to the wise, crack the top nut loose (but do NOT undo it) BEFORE you drop the leg out, still only about 45 mins a side even allowing for fitting spring clamps.
  1. Upper control arms
    By BigWilko in forum Suspension, Wheels & Brakes
    Last Post: 28th December 2012, 18:47
  2. upper control arms
    By chris1804 in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2012, 18:55
  3. For Sale: Upper Control Arms
    By Danger_MouseUK in forum Parts for sale
    Last Post: 5th August 2012, 17:15
  4. upper control arms
    Last Post: 7th May 2012, 14:22
  5. Could it be my upper control arms ?
    By Teza in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2009, 19:03
