Thread: Spraying plastic items like eye brows for instance
    Middlesex
    Trim : SRI
    Engine : CDTI 150 (Z19 DTH)
    Mileage : 100k
    Default Spraying plastic items like eye brows for instance
    Chaps,
    What method do you guys use..
    So far I have rubbed right back, plastic primered and put on the colour.
    Now - some say after 24 hrs run the colour down with 1200 grit wet and dry using lots of water and then laquer, others, just laquer.
    So what have people done previously?
    ta Ant
    WGAF#5
    you need to flat it back down with wet dry otherwise when you lacquer it wont shine
    Hanging Heaton / Batley
    16 Post(s)
    Trim : SRi (VXR Styling)
    Engine : Z19DTH (Re-mapped)
    Mileage : 110k
    To be fair, i only ever flat it back if i dont get it perfect putting the colour on... Each to there own tho... Never had any probs.
    Middlesex
    Trim : SRI
    Mileage : 100k
    Ok - I have 800 grit - would that be OK u reckon?
    dudley
    Quote Originally Posted by AntSSSS View Post
    I normally use 1400 grit for flatting, 800 might be a little harsh, you'll get a better finish with the higher grade.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    1200 grit plenty of water and lightly rub it flat, dry and then laquer, only if the paint finish is not smooth in the first place anyway
    Midlands Mod Shop - NFFC.
  1. Got the brows on
    By 19CDTi in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 10:52
  2. Light brows
    By carlsondavid33 in forum Styling
    Last Post: 7th September 2010, 22:38
  3. eye brows
    By whiskyno7 in forum Styling
    Last Post: 3rd June 2010, 16:40
  4. eye brows
    By cookiejar31 in forum Styling
    Last Post: 14th June 2008, 06:35
