Thread: small oil leak on vectra c sri
    Lancashire
    Default small oil leak on vectra c sri
    i seem to have a small leak coming from between the bottom pulley and the sump , when i stick my finger up there it comes out with wet oil on it lol , its not bad it dont leave anything on the drive but it gets to running down that plastic cover which fastens to what looks like a part of the chassis , its an 07 plate sri 1.8 vvt with 42000 on the clock , does it sound like the crank seal or is there something else i should be looking for ...........
    May 2008
    Tyneside
    Sounds like the crankshaft oil seal to me. I would wait and do this as part of a timing belt change if it's not dripping on your drive. You can get oil additives to stop seals leaking but haven't used any and don't know if they work. HTH
    Regular Member djr69uk's Avatar
    Midlands
    don't suppose you are still under warranty? if so get it sorted with vx..
    Lancashire
    no out of warranty djr , i bought it from arnold " ******s " clark 2 months ago , 30 days and your history , yeah will get it sorted with cam belt tridley ...... thanks for the advice
  1. Small coolant leak
    By VeccyMike in forum Engine & Drivetrain
    Last Post: 1st February 2013, 12:21
  2. Diesel housing looks like it could have a small leak :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 13th May 2012, 23:52
  3. Small Oil LEak @ Turbo. 2.0L DTI
    By mick 1986 in forum Engine & Drivetrain
    Last Post: 2nd February 2011, 21:58
  4. Strange Small Oil Leak 1.8 (Non VVT).
    By John C S in forum Engine & Drivetrain
    Last Post: 21st September 2008, 12:37
  5. Small water leak on 1.9 CDTI
    By MikeyM in forum Engine & Drivetrain
    Last Post: 1st August 2006, 07:01
where does oil leak for vectra c
oil leak in vectra
https:www.vectra-c.comforumshowthread.php109828-small-oil-leak-on-vectra-c-sri
cectra c sri oil leak
vectra vvt sri 1.8 engine oil leak
