Thread: changed pads, grinding noise!?
    West London
    Default changed pads, grinding noise!?
    Changed the front pads on my 1.8 05 Vec, all went fine untill took it for a test drive, theres a grinding noise, not indifferent from that of when theres no pad left on the offside wheel. I've checked and rechecked work but cant see whats rubbing, what am i missing?
    Also, got a new sensor wire, but its atleast twice the lenght of the one there already, with no logical place for it to go, i've checled part numbers and they match - the one thats there goes from pad up to a block thats cabled tied together, with another lead coming off to the caliper.
    Help me!!!!! Thanks
    May 2008
    Derbyshire (south)
    There's a chance the pads are wering into where the others missed, all depends how bad they were, when replaced?
    West London
    they were BAD. no meat on them bones!
    May 2008
    Derbyshire (south)
    If they were that bad, it may have been better to swap the discs too, as these pads will get eaten in no time. a full front set from the dealers is £70ish
    wirral
    57 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    if the discs where chewed up by the old pads then it may possibly be the noise from them, they will eventually re cut the disc smooth again tho, but you will not get aslong out of the pads
    West London
    to be honest the vec isnt getting much use at the moment, i thought id do the pads as a stop gap, so that i didnt damage the discs as much, the pads are cheap brand ones, it was also for the experiance of doing them aswell.
    what am i looking for in terms of damage on the disc? theres a little lip at the top, quite rusty, no obvious scratches or bumps, the whole lot down there is dusty as hell, can i use normal wheel cleaner to get that off or diff stuff cause of the brakes?
    any ideas on the wear indicator wire aswell?
    cheers for the help
    wirral
    57 Post(s)
    Trim : Basic
    Engine : 1.6 16v
    Quote Originally Posted by mattster87 View Post
    cheers for the help
    just looking for bad scoring on the disc, make sure the disc has shiney even face on both sides of it. and that they havent worn to much, a small lip is ok, but no more than a about a mm or 2.
    dudley
    Theres two types of wear sensor, a short one and a long one, you have bought the wrong one, take it back and ask for the shorter one, take the one off the car, and take it with you to make sure you get the correct one before you leave the shop.
    Full Member gibbon7000's Avatar
    lincs
    Theres a possibility that you could of accidently bent the 'disc protector' at the back of the disc. I only know cos this happened to me when i did mine.
    My other car. 1972 1641cc slammed beetle. On the road finally!!
    Regular Member Nav-Man's Avatar
    London
    I'm having the exact same problem.
    My 1.8 Veccy had discs and pads changed by previous owner at Kwik Fit, since I bought the car, I've noticed the grinding noise, took to my local kwik fit who told me pads and discs are new and they can't hear any noise. Not sure what to do now.
    I know that I need two front tyres, could that be causing the problem?
  1. grinding noise turning right
    By jon ixi in forum Suspension, Wheels & Brakes
    Last Post: 28th March 2015, 12:08
  2. LOUD grinding noise?
    By UncleMelon in forum Suspension, Wheels & Brakes
    Last Post: 11th January 2012, 11:21
  3. grinding rubbing noise
    By coooky in forum Suspension, Wheels & Brakes
    Last Post: 28th November 2011, 09:49
  4. Grinding Noise
    By v6boy in forum Engine & Drivetrain
    Last Post: 10th October 2006, 07:52
