Thread: are 3.2 v6 front calipers the same as 1.9 cdti front calipers
    Regular Member gazturbo's Avatar
    glasgow
    Default are 3.2 v6 front calipers the same as 1.9 cdti front calipers
    as above?
    Nope - they're much bigger and use the 314mm discs and pads. Straight fit though...
    Sodding Typical on Sea
    Hmmm,,,,,, this has me thinking about the Saab as my Aero has 314mm discs and the ATE calipers are the same as the 286mm version but with different carriers,,,,,,,
    Could these carriers be an option to fit the 314mm discs? Some investigation required me thinks,,,,,
    The calipers are generic and fitted to lots of different models with different disc sizes, it's the carriers that vary from each model...
    The Saab is based on the Vectra and a common upgrade is for the 314mm disc carriers to be bought, If this is so it's a great little upgrade on Saab's so would benefit the Vectra expecially with the 9-3 uprated caliper and vented x-drilled discs, a wicked look indeed
    Do a search mate - there's laods of people that have fitted them, or the 345mm VXR brakes which are the same as the Hirsch upgrade for the saabs...
    Ahhhh cool many thanks
  1. £80 for 3.0 v6 front calipers shall i?
    By 06sri in forum Suspension, Wheels & Brakes
    Last Post: 3rd September 2014, 20:10
  2. Vectra-C / Signum CDTI Front Brake Calipers (OSF & NSF)
    Last Post: 18th November 2009, 18:22
  3. Front Calipers
    By sriturbo in forum Suspension, Wheels & Brakes
    Last Post: 4th October 2009, 19:41
  4. Front calipers from SRI
    By parsco in forum Parts for sale
    Last Post: 22nd April 2009, 11:20
  5. front calipers? back calipers?
    By kenny1zero in forum Handling & Braking
    Last Post: 19th July 2008, 08:11
3.2 vectra c front brake caliper
vectra c 3.2 v6 gsi calipers
are all vectra c brake calipers same
