Results 1 to 10 of 22
Thread: heater blower problem
    bridgend
    Default heater blower problem
    hi again more problems my heater suddenly working i can hear click on no 1 and 4 setting it may work for 10 seconds then stops again any ideas please
    Regular Member bigdave1701's Avatar
    York
    Have you had water in the footwells recently caused by blocked scuttle drains?
    bridgend
    not that i have noticed no ive tried all the fuses by the passenger door they were ok but it sounds like thats where the clicking noise is coming from does that make sence
    Mar 2007
    North East
    The heater fan is located behind the glove box. The resistor pack which controls the fan speed fails due to water ingress via the pollen filter from the scuttle tray.
    Best to check that the drain in the scuttle panel is not blocked. There are plenty of threads on this forum about this issue and how to repair it (and the speed controller).
    Regular Member Nav-Man's Avatar
    London
    My one had the very same problem, new resistor pack and problem solved.
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    There is a thread, saying get a thermal fuse from maplins for approx 69p, and replace the cream-crackered one in the resister pack.
    Saves the cost of a complete resister pack.
    Check for damp patches on the passenger side floor...also check your scuttle panel for blockages / over-flowing.
    There is also a how 2 for cleaning the important side of the scuttle panel..(one of mine )
    bridgend
    Smile
    thank you for all your input will give it a go the weekend let you know thanks again
    Regular Member djr69uk's Avatar
    Midlands
    if it works on 4 but not properly on 1-3 then it could be resistor pack as said, or it might be a relay. the relay failed on mine - i've just replaced it today. to check the relay take out the glove box and it's on the left hand side behind the fuses. the one you want is blue and rectangular (that's the click you can hear on setting 1). you can take the housing off it and watch for the relay contacts closing when you select speeds 1-3.
    if it is a problem on all speeds including 4 then i think the problem is not the resistor pack or blue relay as speed 4 takes a power feed from another relay that doesn't need to go via the resistor pack or blue relay (hence the 2nd click on 4). it's a direct power feed to the motor. this is from memory so let me know exactly what happens and i'll check the diagram for you. in this case it's almost certainly related to the motor or control...
    bridgend
    Default blower problem
    hi thanks for your advise i just ordered the blue relay having it tomorrow but the heater not working on any setting but i get a click on fon number 1 and then again on number 4 any more ideas the other heater setting work on the other control heat cold etc and vents
    bridgend
    hi just tested all fuses and relays all ok the blower clicks on position 1 and also 4 but does not work isit the motor or switch
  1. Heater Blower Strange Problem - Help!
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 20th January 2014, 22:38
  2. '02 GSI, heater/blower problem
    By RoddyKFC in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2011, 12:54
  3. Strange Heater Blower problem
    By dickybow in forum Vectra C / Signum Car Chat
    Last Post: 8th May 2011, 22:19
  4. Heater / blower problem
    By lacorbiere in forum Vectra C / Signum Troubleshooting
    Last Post: 22nd March 2010, 14:24
  5. Blower / Heater Fan Problem
    By zealot210 in forum Bodywork & Interior
    Last Post: 11th January 2010, 17:38
vecyra c heater loosing power
