Thread: wiper problem please help
    bridgend
    confused wiper problem please help
    hi i have a vectra 03 model sxi i got a problem with wiper hey only work on high speed any sugguestions if its the motor is it easy to replace
    thanks folks any feedback would be gratefull
    Jul 2009
    The Rift, Cardiff
    Check all fuses, if you haven't already, and bench test the relays. It could also be shorting or bad connection, check the plugs and connectors.
    I had the same problem on my golf which was caused by the relay. I went to the scrapy's and got a load for free.
    Jul 2009
    The Rift, Cardiff
    Just seen your other thread on the heater motor. These problems could be related, if the drain in the scuttle tray is blocked it usually leads to water damaging the resistor pack and could have got into the wiper motor plug too.
    Make sure you clean the drain before paying to fix anything. I got a good handful of compost when I cleaned mine the other day.
    bridgend
    just found out mine are rain sensors but still not working any ideas with relays they are under bonnet cheers steve
    teeside
    wiper motors on vectra c have problems with the earth inside the motor im on doing one today thats why they only work on fast speed you have to solder a new earth on inside the motor or its another motor hope this helps
    dave
    Quote Originally Posted by goldwing1bikes View Post
    Here's the HOW2
    Regular Member John35's Avatar
    Jun 2007
    in a white box
  1. Wiper problem help!
    By gunno in forum Electrical & ICE (including SatNav)
    Last Post: 31st March 2013, 21:22
  3. Wiper problem!
    By preecy in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2011, 14:18
  4. Wiper problem
    By stripey in forum Electrical & ICE (including SatNav)
    Last Post: 26th September 2011, 06:32
  5. Another wiper problem!
    By Taffyopel in forum Electrical & ICE (including SatNav)
    Last Post: 9th January 2009, 20:34
