Results 1 to 10 of 11
Thread: 1.8 vvti, lack power low revs?????
    Regular Member mitch's Avatar
    WIGSTON, LEICESTER, LE18
    Default 1.8 vvti, lack power low revs?????
    hi ive noticed that my sri 1.8 lacks power in 1st and into 2nd gear unless you rev it a bit, this is annoying as you think its gonna stall! when its up to 3rd ,4th, its ok and runs ok in top gear, is this normal on these engines or is there a fault that needs looking into ? cheers mitch
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    I find in mine 1st and 2nd plenty of pulling power then 3rd,4th need to reved fairly hard to feel it and 5th is just a slug for motorways and reving that hard in 5th is at silly speeds.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    have you done the airbox mod fella
    Regular Member Exclusive BV's Avatar
    West Midlands
    Mine is exactly the same mate, if you don't give it enough gas on the way into second, it seems to 'lag' and although smooth does not pull strongly until it reaches slightly higher revs. Its no biggy and I have learned to drive the car differently to copy with it
    It's not a slow car though, it goes off like a startled cat once past 3,500 revs in all gears.
    Incidentally, I have not done the air-box mod yet either, I was worried in case it had an affect on my MPG.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Affraid thats a trait of a VVT engine, keep the revs up
    Your more used to diesels which have the power low down
    Regular Member Wolflinn's Avatar
    Camberley
    Yep agree with others.
    I find it fine,kinda 2 cars in one.
    Below 3500 revs a little slow but very good mpg.
    Above 3500 pretty quick, a bit loud and only average mpg for size.
    Also not done air-box mod as I tend to think it is more in the head then on the road.
    thanks guys for the info, yes i do miss the diesel 150ps, wheel spin in each gear wi that Lol
    Northampton
    I think this has just answered the question I have just posted in this forum, lol. Whats this about an airbox mod? mines a 57 plate 1.8vvti exclusiv.
    Do you get a rumble if you dont give it more revs?
    Kev
    S.Shields (Newcastle)
    Mines a 2,2 and feels dead slgish like if i change gear into 2nd at 10mph and then floor it nowt happens till 3.5k
    West Midlands
    Kev,
    Check the how 2 section for the airbox mod.
    It's meant to give you better throttle response and maybe a couple of horses,
    Let us know how you get on
  1. lack of power
    By scottaa73 in forum Engine & Drivetrain
    Last Post: 8th May 2012, 10:49
  2. lack of power
    By Alerxt in forum Engine & Drivetrain
    Last Post: 20th March 2011, 21:00
  3. lack of power
    By dods in forum Vectra C / Signum Car Chat
    Last Post: 2nd July 2010, 20:33
  4. 1.8 VVTi engine, lack of power.
    By mikeopolo in forum Engine & Drivetrain
    Last Post: 23rd November 2008, 00:50
  5. 1.8 VVTi revs
    By Penfold in forum Engine & Drivetrain
    Last Post: 9th February 2008, 15:18
