Thread: Towbar fitters in the NW?
    Regular Member m111kan's Avatar
    Liverpool & Norfolk
    Default Towbar fitters in the NW?
    anybody know of a decent one?
    i already have a detachable westfalia towbar & soon to have the genuine VX electrics for it. i need both fitting.
    any rough prices would be helpful too.
    thanks guys
    alex
    Regular Member ChrisMk1's Avatar
    Rochdale
    Try Mancherster Towbar Centre in Ardwick or Peter Bowman in Bury.
    www.manchestertowbars.co.uk
    www.towing.co.uk
    I have used both before and they really know their stuff.
    Peter Bowman for renting car trailers, and M'cr towbar for when I worked in car hire.
    Chris
    Liverpool & Norfolk
    thanks mate but think im guna do it myself next week now. pick up the 12N electrics in the morning
    info might be useful to someone else though.
    Jan 2008
    Lincs
    Vehicle : Vectra C Hatch
    Trim : Exclusive Plus Pack
    Engine : 1.9 CDTi Z19DTH
    Year : 57
    Mileage : 100k+
    I fitted one of those, and the electrics. One of these makes it a lot easier - http://www.screwfix.com/prods/15976/...p-Drill-4-22mm - just make sure it goes big enough. You can get them on market stalls, they don't need to be top quality to survive for 4 holes.
    You need to clear back the rubber inside the boot and play about with both plates to make sure you have them the right way round. I painted the towbar with underseal too as I fitted it otherwise once fitted the top surfaces will be impossible to get to.
    The detachable bit will fit under the spare wheel on top of the tools. I keep the greasy end in a plastic bag and then the whole thing in it's own cloth bag.
    The Vx wiring fitted and worked fine without and tech2 installation.
    Regular Member Cam's Avatar
    Sep 2009
    Fife
    I just used a 22mm metal hole saw, drilled the holes in no time, even using a cordless drill
    Liverpool & Norfolk
    Quote Originally Posted by Cam View Post
    ive been looking today for somethin to do them with. i saw the hole saw's. but total cost for the adaptor bit, plus a 22mm & 40mm would cost me £35 & i dont know if its worth it as ill only use it once
    Sep 2009
    Fife
    Quote Originally Posted by m111kan View Post
    What do you need that for? the specific wiring kit comes with the socket un-attached and there is a grommet already at the back that you can poke out for getting the cable through?
    When are you doing it? I've got a hole saw that I could post down to you lol, would only cost you the postage back
    Liverpool & Norfolk
    i thought you had to drill a 40mm into the boot to feed the electrics in.....so it says on the 12N instructions??
    ideally i want to be doing it this weekend. lol
    Sep 2009
    Fife
    would be easier to just take the socket off the cable and drill another 22mm hole if the grommet isn't there. Take the trim off in the boot and have a look and see if there is a grommet there, no harm done either way
    Liverpool & Norfolk
    just looked. signum has bit that pops out, vectra has to be drilled
    vec estate my have the pop out (i dont know) but hatch needs drilling
  1. any carpet fitters on here?
    By chris1804 in forum The 'Off Topic' room
    Last Post: 11th September 2010, 19:54
  2. Tyre fitters !!!
    By FIL 4822 in forum Vectra C / Signum Car Chat
    Last Post: 13th July 2010, 23:01
  3. Anyone recommend ICE fitters in NW
    By dennis_signum in forum Electrical & ICE (including SatNav)
    Last Post: 15th May 2008, 09:50
  4. tyre fitters!
    By blr123 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd April 2006, 23:40
  5. Tyre Fitters!
    By nellsey in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2006, 23:12
