Thread: CDR2005 to CD70 Nav
    Scunthorpe
    Default CDR2005 to CD70 Nav
    I got a 2.2i Direct SRi with the CDR2005 in it. Just wondering whats involved in changing it and how easy it is as i can't find any 'How to' on it. Obviously i will need to change the screen as well. Just wanted some insight to doing it.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    well you need to change this:
    ISO plug -> fakra
    Screen
    Screen sourround
    Radio
    Steering wheel controls
    Get a satnav antenna (10£ of ebay)
    If you have ECC also that panel to a 2005 model or newer.
    Full Member Robsey's Avatar
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    As Kemp says...
    1) You will need to use a conversion loom, often used for parrot kits etc (SOT lead which will already have ISO and fakra plugs fitted).
    2) You need to re-wire the display (32 pin plug) the non-canbus wires are in different pin positions.
    3) If you don't have an ECC (climate control), then you wont need to change the panel.
    4) You will indeed need to change your controls to the scroller type, and ensure that the controls are enabled for scroller wheels.
    5) The air-vent surround to suit the display and also
    6) If a clolour screen is to be used, then you'll need the RGB lead .
    North East Cheshire
    14 Post(s)
    Trim : Energy
    Mileage : 131,000
    You will also need an aerial conversion lead (Vx to ISO, and ISO to Fakra).
    and the GPS aerial, which is usually advertised on fleabay as being suitable for a VW / Audi (must be fakra connector)
    There is some change to the can wiring on the display,
    As Follows
    Colour and Pin No (half can) function - Pin No on Full Can
    17 Green not used
    18 White not used
    19 white ECC or DAB (Mid Spd Can -) - move to Pin 18
    20 Green ECC or DAB (Mid Spd Can +) - move to pin 17
    22 Green - Diagnostic (Mid Spd Can +) = Stays the same
    23 White - Diagnostic (Mid Spd Can -) = Stays the same
    25 Green - AirBag Circuit (Low Speed Can) = Stays the same
    28 Green - Illumination, Ambient Temp, Ignition Logic (Low Speed Can) = Stays the same
    Plus on full can display
    19 white-Radio Communication (Mid Spd Can -) to radio pin 10
    20 green-Radio Communication (Mid Spd Can +) to radio pin 9
    The full wiring conversion is detailed in one of my early threads for fitting CD70 to my cavalier.
  1. Cdr2005
    By bigmac in forum Parts for sale
    Last Post: 9th April 2009, 22:24
  2. Cdr2005
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2008, 13:59
  3. Replacing CDR2005 with CD70
    By Lemric in forum Electrical & ICE (including SatNav)
    Last Post: 19th January 2008, 11:56
  4. Cdr2005
    By vectraturbo in forum Electrical & ICE (including SatNav)
    Last Post: 6th August 2007, 14:57
