Results 1 to 10 of 13
Thread: Catalyst help
    Regular Member vectra 120's Avatar
    Washington Tyne & Wear
    Default Catalyst help
    Just went to a garage to ask them to check the car out as the engine management light is on. Said the car sounds like something wrong with the car exhaust so up with the ramps car was running he started from the front ans stop just before the catalyst. The pipe with the mesh on it has split and I could feel air coming out.So back to the counter for the price he told me that the catalyst and this pipe come as one is this right if not could I have the part number for the pipe with the mesh on the price he give was over £700
    he check with parts company and said they could do if for just over £350 what do you all think?
    Steve
    Regular Member Gavin2.6's Avatar
    Liverpool
    Vehicle : 1.9 cdti SRI & 2.6 Vec B & Mk1 Fiesta XR2
    Trim : 2 batteries. 2k RMS. 2x 15 SPL's
    Engine : CDTI 200 16V
    The flexi joint is leaking i presume ? Could you not weld in a new flexi. Cost 40 ish max for right flexi and about the same to have a new one welded in.
    Also checking the web you can easy get a whole new cat for 200 notes. Only a few nuts and its off.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    MIJ welded in a new flexi for me when I had my exhaust done by them, cost about £60 from memory.
    Quote Originally Posted by Ian-Highlander View Post
    That would be a good saving
    Just rang VX they say it comes a full kit also they said I don't have a DPF on my car is that right the said it would be £550 plus vat
    Regular Member crespo's Avatar
    Bournemouth
    Just weld a new flexi pipe to your existing exhaust, any good exhaust centre will do it for between 40 and 60 quid.
    Quote Originally Posted by crespo View Post
    Thanks will check some out on Wednesday
    Can anyone tell me if the front pipe and the catalytic come as one part or could I get this below and replace the damaged part
    http://www.onlineautomotive.eu/ProductImages/301855.jpg
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    I got mine fixed at a custom exhaust place ie the old one was removed and new one was welded in. £75 for the flexipipe, I was told the same as you £300ish for the downpipe with Flexi - eh no thanks
    Gazza4
  1. P0422 Main Catalyst Efficiency Below Threshold (Bank 1)
    By winty234 in forum Engine & Drivetrain
    Last Post: 8th May 2016, 13:33
  2. Catalyst system efficiency below threshold bank 1 not present
    By tomo41 in forum Engine & Drivetrain
    Last Post: 11th July 2011, 23:00
  3. PO422 catalyst efficency thresold 1 or somat
    Last Post: 19th June 2011, 20:49
  4. hmmm catalyst converter
    By Kamikazy in forum Tuning
    Last Post: 22nd September 2006, 04:19
