Results 1 to 10 of 16
Thread: How can I replace the front turn signal bulbs?
    Regular Member Lao's Avatar
    Aug 2009
    Romania, E.U.
    Vehicle : Vectra C Estate Automatic
    Trim : Elegance
    Default How can I replace the front turn signal bulbs?
    I can't believe I can't find a way to do it. I have a prefacelift, with xenon and AFL. How can I replace them?
    I tried rotating the plastic that sits right behind the bulb, but that is one piece with the headlight, it can't be turned.
    I tried removing the back cover, but I can't get to the bulb.
    Any ideas?
    Admin plasma's Avatar
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    You wont like this... You have to cut it away with a stanley knife or such and change the bulb, then you need the Vx service/repair kit to seal it afterwards....
    Plasma's Tech2 services are now partially open and able to provide services
    Come Join our new forum Insignia Owners.com for all your Insignia chat and needs
    Aug 2009
    Romania, E.U.
    Trim : Elegance
    You're joking right?
    The fact is that I purchased a pair of silver bulbs that I wanted to replace the orange ones. If this is the only way I can do it, I think I can live with the orange ones for now.
    Sodding Typical on Sea
    Is this the same in facelift Vectra's too??? I plan on fitting my Diadem's as soon as I get the car,,,
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    No. In the facelift, you simply have to remove the bumper, then the headlight units, then replace!
    Quote Originally Posted by ghostrider View Post
    Ahhh nice and sleazy then
    On another planet
    Engine : 2.0
    Quote Originally Posted by Derek Mc View Post
    Simples..... Luckily, they seem to last quite a while!
    Apr 2009
    Derby
    Can you also do the driver side by removing the airbox? (At least in the CDTI 150 facelift)?
    I need to do this as i have an intermittent on that side - the bulb hasn't gone it just occasionally goes open circuit. It happened on the LH side recently and I cured it by bending the contacts in the bulb holder slightly. On that occasion I had the bumper off to replace the outside air temp sensor so was easy.
    space
    yes as i found out in the middle of germany last year nice a simple bulb change NOT
    On the Forum
    265 Post(s)
    Engine : 150
    Mileage : 74000
    Quote Originally Posted by Lao View Post
    No joke mate, took them out to do exactly the same thing as you. Sealed unit!! theres a field remedy on how to change the bulbs as per what i said lol..
  1. Turn Signal Lamp/Indicator Warning
    By Nimbus in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2012, 23:58
  2. turn signal
    By vectraross in forum Vectra C / Signum Car Chat
    Last Post: 2nd August 2012, 22:15
  3. How to remove turn signal stalk
    By bnam in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2009, 16:58
  4. How do you replace bulbs in front fog lamps??
    By wittsy` in forum Electrical & ICE (including SatNav)
    Last Post: 15th January 2009, 18:57
  5. 04 vectra turn signal problem
    By azn_007 in forum Electrical & ICE (including SatNav)
    Last Post: 12th November 2007, 22:43
how to change indicator bulb on vauxhall vectra
vectra c indicator bulb
vectra 2006. change turn signals bulbs
vectra c front indicator bulb change
how to change indicator bulb on vauxhall vectra drivers side
how to change a turn signal bulb in a 2008 opel vectra
how to change a indicator on a vauxhall vectra
vectra front indicator bulb replacement
vectra c indicator bulb change
change indicator bulb vauxhall vectra
signum front turn signal replacement
how to replace ns indicator bulb on vectra c
replace an indicator bulb on vectra c
change indicator bulb vectra 2007
06 vectra front indicator bulb replacement
indicator change vectra
vectra indicator bulb change
farside indicator bulb vectra
change indicator bulb vectra c
vectra c xenon bulb replacement
aignum afl turn signal bulb replacement
vectra c change fron turn bulb
how to change front indicator bulb 2006 vauxhall vectra
vauxhall vectra 2008 turn signal replace
