Thread: Rear Brake Pads / Handbrake
    Wrexham
    Default Rear Brake Pads / Handbrake
    I got into bother when trying to replace rear pads. Trouble arose when trying to release auto handbrake adjuster to accomodate extra thickness of new pads. It sounds simple in Manual i.e."Push the piston & spring rearward with suitable tool. hold them in this position and press down the transport fixing to lock mechanism in the released position". For some reason I could not even budge the piston/spring backward. I am sure there is some simple action I have missed. Would appreciate advice please.
    Arwyn
    scotland
    it needs wound in mate not pushed !
    you might do it wi long nose pliers with some pressure while turning
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    or brake rewind tool..
    wirral
    36 Post(s)
    Vehicle : Mk1 renault scenic... I know I know but it drives
    Trim : Basic
    Engine : 1.6 16v
    as said mate needs winding back, i have doen it with circlip pliers, but wasnt the best experience. my forearms where killing me afterwards
    scotland
    I made my own rewind tool, used an old socket and ground it away leaving two points to go inside piston then some threaded rod and flat plate .... schimples
    Wrexham
    Default Rear Break Pads / Handbrake
    Sorry! It is the handbreak Adjuster I wanted to release not the Break Pad cylinder.
    Thanks,
    Arwyn
  1. Rear Brake pads
    By tangoman in forum Suspension, Wheels & Brakes
    Last Post: 24th July 2012, 13:19
  2. rear brake pads
    By waynevvti in forum Suspension, Wheels & Brakes
    Last Post: 9th April 2012, 16:17
  3. Rear Brake Pads
    By Das in forum Suspension, Wheels & Brakes
    Last Post: 3rd October 2010, 13:15
  4. Rear Brake/Handbrake Setup
    By nikroc in forum Suspension, Wheels & Brakes
    Last Post: 15th March 2010, 18:52
